Old 02-13-2014, 01:30 PM
u47u67u87 u47u67u87 is offline
Default No Sound Coming Out of Pro Tools
Hello,
This is my first time on the forums.
I am importing audio files from my Logic projects to
work in Pro Tools.
When I try to play back the audio in the edit window, no sound comes out.
Unfortunately, my pocket isn't big enough for the full version of
Pro Tools 11 HD, so this is a 30 day demo.
I would be absolutely more than grateful if you
could help me solve this problem.
Thanks,
u47u67u87
Old 02-13-2014, 02:02 PM
theresbuzz theresbuzz is offline
Default Re: No Sound Coming Out of Pro Tools
Hey,
you need to provide a few points of reference otherwise it´s hard to pinpoint your problem.
First check the hardware make sure you have everything plugged into your system.
Second check in Pro Tools under Setup-->Hardware if your soundcard is recognised correctly.
Third check the playback engine in the setup menu.
Fourth check in the mixer on which output you are sending your audio and recheck that in you I/O setup, if this output corresponds to the correct outputs on the soundcard.
Hope it makes some sense.
Old 02-13-2014, 10:25 PM
JFreak's Avatar
JFreak JFreak is online now
Yes, check the i/o setup window, there's everything your mixer will ever use. If it's wrong, it is wrong.
And welcome to the forum!
Janne
Old 02-14-2014, 03:10 AM
Originally Posted by u47u67u87 View Post
Hello,
work in Pro Tools.
Thanks,
u47u67u87
Welcome to the forum.
I'm going to assume you have your audio I/O interface correctly in OSX Audio/MIDI Setup and System Sound because you're getting audio in Logic. When you start Pro Tools hold down the 'n' key and you should be presented with a dialog box allowing you to select the audio engine of your choice. When you do that go to Preferences and in every page for Input, Output and Buses select default and that should give you the routing you need to get audio in and out of PT. And make sure you're selecting the correct output (which will vary by name depending on your specific audio interface but generally called Main Output) on the track you want to listen to. Once you get that down then there's all sorts of audio routing to try.
Jack
QAPLA!
No sound coming from software instruments on Pro Tools SE 8.0.3 taylor6192 Pro Tools SE and Essential (Mac) 9 09-08-2014 05:53 AM
Just setup pro tools 10 and have no sound coming through the ouput mingalls Pro Tools 10 2 08-13-2012 09:50 AM
Pro Tools 9.0 no sound coming out of my monitors shamanrock Windows 2 08-05-2011 09:18 PM
No sound coming through my C|24 gulbis ICON & C|24 2 10-04-2010 04:44 AM
no sound coming out of pro tools Sweepxcore Pro Tools M-Powered (Win) 12 03-19-2010 11:23 AM
