Old 03-29-2013, 04:37 AM
SJDEMS SJDEMS is offline
Default Motu 828 setup help needed
Hi there.
First post, so hi to all!
Just recently bought Protools 10 (student edition) and I am having problems getting my soundcard/s recognised. I have a Motu 828mk3 and a Motu Traveler hooked up via lightpipe. I have been running Ableton this way whithout a hitch for some time, but can't seem to make this work in Protools. I have also looked online but can't find any relevant info. Any light on this much appreciated...
Old 03-29-2013, 04:39 AM
Default Re: Motu 828 setup help needed
On Mac Snow Leopard
Old 03-29-2013, 05:16 AM
groundcontrol's Avatar
groundcontrol groundcontrol is offline
It's still working with Ableton?
Can you please send yourself over fiber to go spam some other forum?
Darryl Ramm
Old 03-29-2013, 06:39 AM
crizdee's Avatar
crizdee crizdee is offline
Originally Posted by SJDEMS View Post
Hi there.
Try going to Setup / playback engine. and see if the Motu is available in the list at the top as an audio engine?
Aslo try booting Pro Tools holding the N key which will boot PT without any inteface assigned then try assigning the motu as the audio engine as above.
In the AMS audio midi setup. is the Motu showing as an audio device? is it setup to be the active input and output!
The 828MK3 alone should definitely work, not sure about the traveller as well.
you've got the latest drivers for the Motu?
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-29-2013, 07:11 AM
jbrown7282 jbrown7282 is offline
Hi there.
To get both interfaces to communicate with Pro Tools you must set up an Aggregate Device.... connect you gear and open up Audio Midi set up configure that then start Protools and in your playback engine select the Aggregate device...
Old 03-29-2013, 07:31 AM
This is not needed. He has the traveller connected to the Interface via ADAT, he was not asking about aggregating both devices as interfaces. If his setup works via ADAT with another DAW it should be simple to just use the same setup in Pro Tools.
Old 03-29-2013, 07:39 AM
Hi there.
Chris has already explained the basic steps to select the Playback Engine.
You need to be a lot clearer when you say "can't seem to make this work". Make exactly what work? Use the 828Mk3 as a playback engine at all? Or is that appearing as the Playback engine but something is not working with the ADAT connectivity to the traveller? You need to clearly describe exactly what you are doing and what is exactly not working like you expect.
When you say this works with Ableton you mean on this exact same computer? or Ableton installed on a different computer?
Darryl
Old 03-29-2013, 07:48 AM
In the interest of troubleshooting, I would set the Traveler aside and just work on getting the 828 going
Old 03-29-2013, 05:27 PM
Your Right Darryl.... In that case He would have to refer to the MOTU Manual......
You would have to set up Cue Mix and the MOTU Audio Set up app to tell the 828 where to pass signal.....to the Traveler.....
Old 03-29-2013, 08:00 PM
Thanks for your responses.
In answer to the questions asked,
Yes Ableton is how it should be (all I/O appear)
Motu 828iii is available in Playback Engine/AMS.
Protools I/O sees only a stereo I/O. All of the others are not selectable (grey)
Lastest Driver installed.
Daryl> Hope this clarifies.
I am after all of my I/O on my cards to show up in Protools.
The two cards talk to each other fine. I can run the current soundcard setup on the same computer with ableton without any probs.
On an Audio Track Input drop down only built in mic 1-2 appears.
Pretty sure this is my settings in Protools somewhere...
MOTU 896hd setup billyborden macOS 6 03-21-2018 02:33 PM
Motu MTPAV Manual Needed - Also, Q Regarding it's clock Table Syrup Records Digidesign Hardware & Software 0 11-09-2009 08:17 AM
MOTU Digital Timepiece setup Elecshop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-04-2007 08:16 PM
MOTU MTP AV OSX - MIDI Setup is Empty Howardk Pro Tools TDM Systems (Mac) 10 01-18-2005 02:14 PM
How does 002 compare to 001 & also logic/motu 896 setup? cane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 10-29-2002 12:42 AM
