Old 03-07-2012, 12:08 PM
Earfatigue Earfatigue is offline
Default Multiple computers = multiple copies?
Ok this is going to sound a bit silly, but here goes:
I used to use a laptop for my PT work, but have recently bought a desktop. I've enjoyed being able to transport my laptop and rig to various spaces for source recording, but I'm excited about the processing power of the desktop.
Do I need two separate copies of PT for each computer, or can I authorize one copy on both? The cynic in me says they'll want as much money off of me they can get, but if I can use my hardware with any given device, why not my software?
Mac Intel Core 2 Duo
2.33 GHZ
2 GB RAM
Snow Leopard
ProTools 9.0.6
Digirack 003
Old 03-07-2012, 12:11 PM
derFunkenstein derFunkenstein is offline
Default Re: Multiple computers = multiple copies?
You only need 2 licenses if you want 2 iloks so you don't have to swap the device between them. If you don't mind moving the ilok around, you only need one license.
Old 03-07-2012, 12:25 PM
No kidding? Well, consider my cynicism pwned!
2.33 GHZ
2 GB RAM
Snow Leopard
ProTools 9.0.6
Digirack 003
Old 03-07-2012, 12:28 PM
reichman's Avatar
reichman reichman is offline
Get one system working exactly the way you want it, then clone the hard drive and put that in the 2nd system. Then all you have to do is carry around the iLok. Very easy. Long live iLok.
Old 03-07-2012, 03:33 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
You can't system clone 2 machines unless the hardware is exactly the same, and even then it may cause issues.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
Old 03-07-2012, 03:49 PM
reichman's Avatar
I used to think that was true until I did a number of empirical tests. I've moved my entire boot drive (Pro Tools (9, then 10), Logic, countless plug-ins and additional apps) from a Harpertown Mac Pro (003), to a Santa Rosa MacBook (no hardware), to a Westmere Mac Pro (with an ICON!), to a MacBook Pro (MBox2). Mac OS X and Pro Tools are astonishingly portable. All you have to do is hold down 'n' while launching Pro Tools to choose the new hardware.
No issues.
Old 03-07-2012, 04:18 PM
No issues.
I would consider that lucky at best. Perhaps since you were going from a Mac Pro to another Mac Pro (different versions) it worked. I would have serious doubts it would work between Mac Pro and a Macbook Pro due to different graphics cards, hard drives, processors, etc. I would recommend simply installing Protools on both systems from the discs or the downloaded installers.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 03-07-2012, 05:16 PM
reichman's Avatar
Default
Portability is one of the huge unadvertised features of OS X. The OS automatically adapts to the available hardware. I've gone from a Mac Pro to a laptop with a cloned drive countless times with 10.6/PT9 and 10.7/PT10.
The saved time is enormous. All of your preferences, custom plug-in presets, plug-in versions travel smoothly. Don't knock it until you try it...
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 03-07-2012, 05:47 PM
CME CME is offline
Default
I haven't tried it but I believe it. There are very few hardware options when compared to a windows system. So there really aren't that many drivers needed. The only exception being when hardware comes after a software release. Like the new Mac mini (specifically the server version), it doesn't play well with snow leopard. And conversely some older intel macs aren't supported in lion. But as long as all your systems are supported by the OS version you're using I can totally see it working.
But back to the OP. You can install PT on every computer you have access to. But it will only run on the one the ilok is plugged into. So you only need 2 licenses if you need to run pro tools on 2 computers at the same time.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Multiple computers rodpost Pro Tools 10 1 01-30-2013 07:59 PM
PT9 on multiple computers ? BigEvil Pro Tools 9 6 12-12-2010 01:07 PM
simultaneously edit velocity for multiple copies of an event? bms9nmh MIDI 3 05-01-2009 04:43 PM
Using multiple copies of OS X copywell Pro Tools TDM Systems (Mac) 1 01-04-2004 01:11 PM
OMS does not allow multiple copies... c_hebb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-08-2002 07:04 PM
