Old 01-17-2012, 02:30 PM
digi003 digi003 is offline
Default Best group / Aux set up
Might be a bit of an obvious one this but what the best way to set uo grouping in PT10.
For example if I have a drum mix of say 8 channels and i want to group them all together to one fader so i can turn up the whole level of the drums or down
using one fader and on that group fader i might want to insert a compressor.
also in this example if i change one of the levels of the 8 channel drums going into the buss i might not want it to affect the compressor.
So say if i set the compressor when all the drum are running but in the arrangement the kick drops out for a bit i wouldn't want it to greatly change the sound of the reset of the drums
Protools 10: Asus M2N 1392 : 8GB Crucail DDR2 800 :
MBOX PRO2
Old 01-17-2012, 02:51 PM
Oblivion777's Avatar
Oblivion777 Oblivion777 is offline
Default Re: Best group / Aux set up
I'd use VCAs ... assuming you have CPTK(2) license.
Main DAW: MacPRO 7.1, 16-Core Xeon 3.2GHz, 196 GB RAM, OSX 10.15.2, HDX3, PT 2019.12 Ultimate, 2x UAD-2 PCIe Octo's, Raven MTZ, 1x HD Omni, 2x HD I/O's, 1x MTRX and some more cool stuff...
Auxilary DAW: MacBook Pro with Retina Display (2012), 2.6GHz quad-core Intel Core i7, 16GB RAM, OSX 10.13.6, PT2019 Ultimate, 1x UAD Apollo Quad Audio Interface /w Thunderbolt Interface (v9.x)
Old 01-17-2012, 03:16 PM
slater05 slater05 is offline
If you don't have the CPTK, than routing all the drums to an AUX is a good way to do it.
This is the way I do it, I route all the different sections, Drums, Guitar, Vocals to their own Aux tracks, then to a 2TRK Aux, then the Master.
I have it set up this way so that if I'm running low on CPU, I can quickly record one of the sections to a stereo audio track and disable them.
Doing it that way, you can adjust the level of the Aux, all of the drums, without having to group them, so you can adjust their levels separately also.
www.mikeslatermusic.com
PTHD9 Certified Operator
15" MBP 10.7.2
Pro Tools 10.0
Apogee Duet
M-Audio BX5A's
Old 01-17-2012, 03:53 PM
lownotesinc lownotesinc is offline
Just curious, Why the 2TRK Aux before the Master? Is that so the Master doesn't
get overloaded?
-LN
Old 01-17-2012, 04:01 PM
so route all channels to an aux track and inserting a compressor on that track
but what about my question regarding how much the compressor will be worked if say in the arrangment things drop out in th drums
MBOX PRO2
Old 01-17-2012, 04:24 PM
upscaps upscaps is offline
If you used individual reverb sends on the 8 channels remember those 8 drum track levels are staying the same but you are lowering their volume on the aux group.
You will now have more reverb than you did because the reverb level did not lower with the aux volume.
A way around this is to have all the drum reverbs/delays output to that same drum group aux channel.
Old 01-17-2012, 04:25 PM
I route it to a 2TRK because I prefer to record the mix to an audio track in the session rather than bouncing out.
So the 2TRK acts as my mastering strip also.
Also at the same time, then I can have reference tracks in the session, routed to A 1-2, and they aren't affected by the mastering on the rest of the session.
15" MBP 10.7.2
Pro Tools 10.0
Apogee Duet
M-Audio BX5A's
c/24 age group BLUNTBRAD ICON & C|24 5 12-09-2013 04:28 PM
1 track in group isn't responding with group! gregwor macOS 7 01-25-2011 07:22 PM
The Group Won't Go Away! Sound Student 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-29-2010 04:26 PM
Group Bug? Kris75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-06-2008 12:30 PM
Group Persists for Resizing Even When Group Turned Off. holden Pro Tools TDM Systems (Mac) 3 06-24-2008 03:31 PM
