Old 04-05-2011, 06:42 AM
macaholic macaholic is offline
Default Upgrade to PT9, now I can't record from Transport.
OK, so it seems as if there is a pref somewhere that is causing this behaviour, but I can't seem to find it in PT9.
When I arm a track, I used to be able to press Record on the transport, and then when I hit play, it would start recording. Now it seems that when I hit play, the track stays armed but won't go into record.
If done all the usual Prefs trash, etc, and figured at this point, it is just operator error. Pressing "3" on the 10 key pad still works.
Any guesses?
JC Richardson C.A.S.
Magick Lantern
Atlanta
Old 04-18-2011, 05:15 PM
AlexDC AlexDC is offline
Default Re: Upgrade to PT9, now I can't record from Transport.
I had a similar issue in a studio with a d-command the other day, we tried doing a couple hard resets of the system, that seemed to fix it.
-Alex
Old 06-13-2011, 03:26 PM
nuvintage nuvintage is offline
Having same problem but restarting and hard booting is not fixing it. Anyone else?
Old 06-13-2011, 04:40 PM
The golfer The golfer is offline
When using Protools 9.0.1 and the Euphonix system 5 MC we had the same problem (Punch in issues). This has been fixed in 9.0.2. Are you by any chance using 9.0.1?
Serge Hamel
Mixer / Sound Designer
http://www.netpostproduction.com
http://immersivesoundvr.com/
Old 06-23-2011, 12:05 PM
banana boy banana boy is offline
Check this thread - pretty sure this is the same syndrome. Good news: easily fixed! IHTH.
Yebo!
Duncan
www.shillingfox.com
Record button in TRANSPORT Hanswurstlsepp ICON & C|24 5 07-24-2010 01:18 PM
Cant Enable Record On Transport -- Help BlackOxx Pro Tools TDM Systems (Win) 0 03-25-2010 04:26 PM
Transport Record ? , >?"@%^!!!!!!! Blain 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-28-2008 07:02 PM
transport record lock not working JC925602 Pro Tools TDM Systems (Mac) 3 05-17-2006 10:40 PM
going back to 7.0, transport record lock is no go JC925602 Post - Surround - Video 3 05-03-2006 03:22 PM
