Old 02-25-2008, 01:38 PM
cinetj cinetj is offline
Default Trim automation mode: what is it for?
I woul like to know what is the use of the trim automation mode.
Thanks
Old 02-25-2008, 02:52 PM
Andre Knecht Andre Knecht is offline
Default Re: Trim automation mode: what is it for?
Let’s say you have a track with existing automation. You like the Automation behavior, but its overall level is wrong. Trim mode allows you to add and/or subtract values (indicated with the fader), while retaining the existing automation. When in Trim mode, the fader turns Yellow in color and snaps to its 0db position. Move the fader up to add; move the fader down to subtract.
Trim generates its own Automation curve, which is fully editable. Once satisfied with the changes, one can “coalesce” Trim and existing Automation, making the changes permanent (and allowing for new Trimming events).
Take a moment and read all the details in the Reference Guide.
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 02-25-2008, 03:02 PM
Thank you
Old 02-25-2008, 05:34 PM
Irl Sanders Irl Sanders is offline
Particularly useful for doing different mix versions, such a "vocals 2 dB hotter" or "1.5 dB softer". Used to do this when printing mixes to tape from the big analog consoles, so that if the producer/band/label/mastering engineer had comments about the vocal levels, you could just edit between the different mixes and not have to go back in the studio and recall the mix.
Irl Sanders
Music Editor
LA, CA, USA
Trim automation mode in Complete Production Toolkit? thegun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 21 02-26-2009 12:26 PM
Automation... Trim Mode in LE/MP? maufau 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-19-2008 03:49 AM
Protools LE trim automation mode Igotsoul4u 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-07-2007 01:00 AM
trim mode causes delay in automation matt connolly ProControl, Control|24, Command|8 2 09-27-2004 11:11 PM
using trim mode causes steps in automation RIO Pro Tools TDM Systems (Mac) 0 08-19-2004 02:51 PM
