Old 03-15-2007, 10:56 AM
quantise quantise is offline
Default Bug in Sample Output Assign
I have the EXS Stereo Drums patch loaded into Structure.
I have assigned all of the kick drums in the 4 parts to output to Bus2. I have assigned an Instrument track in PT to listen to Bus 2 from Structure and it all works. Kick is coming into PT on its own track. I have saved the patch as patch plus seperate audio files, this is fine but when I try to reload the patch the seperate assignment for the kick drum is forgotten.
On investigation in the editor, one of the kick drum samples, of which there are two for each part, is re-assigned to 'Part' as output instead of Bus 2 as previously assigned. Reassigning them manually again gets the patch working. Tried saving as a monolithic file but it has the same problem.
Regards,
John
PT 2021.12 Native 2x Universal Audio Apollo 8p and Apollo 8
Mac Studio. M1 Max. OS Monterey 12.3
Avid S3 and Avid Dock. Dynaudio BM5's.
Old 03-22-2007, 06:51 AM
Wolfram K's Avatar
Wolfram K Wolfram K is offline
AIR Music Technology
Default Re: Bug in Sample Output Assign
Thanks for reporting,
this behavior has been logged and is going to be tested and fixed.
Wolfram K
C|24 - can I use the control surface to assign output bus? A Chapman ICON & C|24 8 01-03-2011 04:12 PM
Sound output assign? manyrains 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-19-2009 09:07 AM
Can't assign output, not enough DSP? crizdee Pro Tools TDM Systems (Mac) 2 04-04-2008 12:05 PM
PT le 6.7 Midi Problem (cant assign output) dsmith 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-03-2006 07:41 PM
assign audiosuite preview to output? StainedClass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-12-2003 10:52 PM
