Old 12-04-2005, 10:54 AM
Riccardo Corbari Riccardo Corbari is offline
Default problem with midi program change
hi. i cannot send midi program change. the problem is that if i input (in the midi program change pop-up window) a number in either "controller 0" or "controller 32" fields, as i click in the other field the number just inserted disappear.
do you have any solutions?
thank you,
Studio Fuoriporta - Italy... verily everywhere...
Old 12-04-2005, 05:13 PM
joji joji is offline
Default Re: problem with midi program change
I called about this same issue myself. Digi knows about it. But you should call tech support and put a compaint in. Last time i checked they could not find my complaint. They will fix it in the next update if they get enough complaints. So give a call. This i unexceptable. I think sometime Digi thinks most of there users are live players and non midi guys which is untrue.
Old 12-05-2005, 02:19 AM
support is always unreachable, so... DIGI READ HERE! come on, be serious.
Old 02-04-2006, 04:35 AM
today, Pro Tools still miss the Controller 0 program change. Any news, DIGI?
Old 02-04-2006, 05:06 AM
crizdee's Avatar
crizdee crizdee is offline
Its a known bug! fill in a bug report form, the more requests they get the quicker the engineers will fix it.
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-04-2006, 07:57 AM
aux aux is offline
Same here, the bank changes 0 and 32 dissappear immediatly when filled in. The only way to send them, is by using/creating a .midnam file. But these do not always load properly or at all.
Aux
MassiveMusic
SOS article
Old 02-21-2006, 09:41 AM
Chris
how to report a bug via software? is it possible that we pay tenth thousands dollars for these stupid bugs?
Old 02-21-2006, 12:47 PM
burningbusch burningbusch is offline
Full program changes can be entered using the MIDI Event List.
Busch.
Old 02-21-2006, 09:23 PM
Cawbaby Cawbaby is offline
Riccardo, I have the same problem,
but, though the numbers disappear as you insert them, mine still works and stores (invisably) the program assignment.
Dr. Caw Recording
www.drcaw.com
Old 02-22-2006, 09:06 AM
DigiTechSupt's Avatar
Cawbaby is correct - the program change will still occur, it's just that the display reverts to default after entering a number.
A bug has been logged on this and I'll add your comments to the record.
Avid Audio Tech Support
Support FAQ
Midi Program Change Problem tony_cb Pro Tools 10 1 05-16-2013 04:05 AM
Program change via MIDI on PT7 JSPurcell Tips & Tricks 1 09-12-2010 11:19 PM
Program change problem peter99 Pro Tools TDM Systems (Mac) 1 02-24-2007 12:16 PM
midi program change porkipine MIDI 3 05-14-2005 04:52 AM
Midi Program Change Bug? Nocturnal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-28-2002 05:54 PM
