Pro Tools 12 Midi Not Working
I'm having an issue with PT 12 and midi. I upgraded to PT 12 from PT 8LE some months ago, and I ironed out all the initial issues I had, but today is the first time I've tried to use midi and it's not working/there is no signal.
A few notes: -I am not using a midi controller/keyboard. I am simply programming the midi manually on the keyboard roll, but there is no sound as I input them or on playback, and the track does not show any signal as it passes over the notes. -When viewing the track in 'clip' mode, the clips appear to be almost grayed out. I have verified they are NOT muted, and the track is definitely active. At the bottom I have attached a screen shot showing what the track/clips appear like. -I have opened old sessions which contained midi, and those sessions are having the exact same issues with the midi tracks. Any help would be appreciate, thanks in advance! |
Re: Pro Tools 12 Midi Not Working
a little more info please thank you
Indeed^^^ grey'd out midi means it is not assigned to a sound source
The input is set to 'no input'
The output is set to the 'Mains' output. (Same output as everything else which is functioning properly in the session) I am trying to use this for a drum reference, with the Xpand plug in, so an instrument track. thanks |
OK after reading your responses I played around and got it to work. I went to view, and clicked "Edit Window Views;" then I clicked "instrument tracks" and I noticed Xpand showed up in the pane but was greyed out. I clicked it, and selected 'track 1' and now it appears to be working. I'm not exactly sure what I did, but it's working! thanks for helping me get there haha
This happens to me every day of the week. I suggest keeping a note in the notepad area of each VI track on what it's supposed to be assigned to
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX |
Will do, thank you
MIDI not working in Pro Tools 11.0.1 | asaffulks | Pro Tools 11 | 19 | 10-15-2016 10:54 PM |
Pro tools 12 midi in not working | Hafeez | Pro Tools 12 | 1 | 08-16-2016 12:48 PM |
Midi not working in Pro Tools 11 | kg366 | Pro Tools 11 | 2 | 09-08-2015 06:45 PM |
Midi Control Not working in Pro tools 11.0.1 but works in pro tools 10.3.6??? | bleudog | Pro Tools 11 | 17 | 04-30-2014 03:13 PM |
Midi Not working on Pro Tools 8 | Tesar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-11-2009 10:50 AM |
