Old 01-20-2018, 10:02 AM
needled39 needled39 is offline
Default Pro Tools 12 Midi Not Working
I'm having an issue with PT 12 and midi. I upgraded to PT 12 from PT 8LE some months ago, and I ironed out all the initial issues I had, but today is the first time I've tried to use midi and it's not working/there is no signal.
A few notes:
-I am not using a midi controller/keyboard. I am simply programming the midi manually on the keyboard roll, but there is no sound as I input them or on playback, and the track does not show any signal as it passes over the notes.
-When viewing the track in 'clip' mode, the clips appear to be almost grayed out. I have verified they are NOT muted, and the track is definitely active. At the bottom I have attached a screen shot showing what the track/clips appear like.
-I have opened old sessions which contained midi, and those sessions are having the exact same issues with the midi tracks.
Any help would be appreciate, thanks in advance!
Old 01-20-2018, 11:29 AM
john1192 john1192 is offline
Default Re: Pro Tools 12 Midi Not Working
A few notes:
even though you do not have a keyboard .. do you have an input and output assigned to your Midi Track ?? or are you using an instrument track ??
a little more info please thank you
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-20-2018, 02:49 PM
Indeed^^^ grey'd out midi means it is not assigned to a sound source
Old 01-21-2018, 07:29 PM
The input is set to 'no input'
The output is set to the 'Mains' output. (Same output as everything else which is functioning properly in the session)
I am trying to use this for a drum reference, with the Xpand plug in, so an instrument track.
thanks
Old 01-21-2018, 07:37 PM
OK after reading your responses I played around and got it to work. I went to view, and clicked "Edit Window Views;" then I clicked "instrument tracks" and I noticed Xpand showed up in the pane but was greyed out. I clicked it, and selected 'track 1' and now it appears to be working. I'm not exactly sure what I did, but it's working! thanks for helping me get there haha
Old 01-21-2018, 08:26 PM
TNM TNM is offline
you didn't do anything wrong, pro tools randomly loses it's VI midi assignments when loading projects.
This happens to me every day of the week.
I suggest keeping a note in the notepad area of each VI track on what it's supposed to be assigned to
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX
Old 01-22-2018, 02:04 PM
Will do, thank you
MIDI not working in Pro Tools 11.0.1 asaffulks Pro Tools 11 19 10-15-2016 10:54 PM
Pro tools 12 midi in not working Hafeez Pro Tools 12 1 08-16-2016 12:48 PM
Midi not working in Pro Tools 11 kg366 Pro Tools 11 2 09-08-2015 06:45 PM
Midi Control Not working in Pro tools 11.0.1 but works in pro tools 10.3.6??? bleudog Pro Tools 11 17 04-30-2014 03:13 PM
Midi Not working on Pro Tools 8 Tesar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-11-2009 10:50 AM
