Go Back   Avid Pro Audio Community > Live Sound > VENUE Live Sound Systems
Old 01-24-2012, 01:57 AM
[email protected] dj-mayo@fastwebnet.it is offline
Default Recording from SC48 to Cubase
I everybody, I'm trying to record 18 tracks (with no plugins) from SC48 to protools 10 but I receive error 6101 (CPU overload) in pro tools. In order to try in another way, can I record from FWx to Cubase? how to set up properly?
Thank you so much for your help!!!!!
Old 01-24-2012, 05:03 AM
BradLyons BradLyons is offline
Default Re: Recording from SC48 to Cubase
The SC48 is meant to record to Pro Tools, not to Cubase. As to the CPU overload, what computer are you using and are you recording to a dedicated drive for audio that is meant for audio?
Thank you,
Brad Lyons
www.howavl.com
Old 01-24-2012, 05:53 AM
Mac book pro 2008 with 3 gb ram and lion OSX, external WD hd (USB3).
Old 01-24-2012, 07:49 AM
voidmix voidmix is offline
Even though you are using a USB3 drive the USB interface on your laptop is certainly not USB3 capable, being that it is from 2008. Plus, you'd want to make certain the drive spins at 7,200 rpm. Try using a FW 800 drive that spins at 7,200 rpm and see if that gets you rockin'.
Old 01-24-2012, 11:56 AM
doug sjostrom doug sjostrom is offline
For 18 trks, just see if you can record to the system drive. A failure wouldn't mean anything really as I can't speak for Cubase. Also make sure no other apps are running. You might also try turning off Airport. It shouldn't matter but you never know.
Doug Sjostrom
Old 01-25-2012, 01:40 AM
I've done everything about this...
Old 01-29-2012, 09:48 PM
MartyBee MartyBee is offline
Cubase works great as an alternative to pt 10
Old 10-24-2012, 11:23 AM
SeanDerMan SeanDerMan is offline
hi.
reopening an old post... Marty are you saying that Cubase works with Venue 3 via FW on a MacBook Pro?
Old 10-25-2012, 03:25 AM
I think the only think that you have to do is to install FWx drivers on your mac, than cubase will see sc48 like a soundcard 32/32
Old 10-25-2012, 06:53 PM
Pro Tools has never supported USB drives for recording on any Mac. You might get away with 18 tracks on the system drive if you do 2 things; use no plugins while recording, and set the buffer to 1024. Next move would be to add a good FW drive with dual FW400 ports(daisy-chained between the consoleFW and the laptop FW).
32CH recording with SC48 liamclifford VENUE Live Sound Systems 5 09-07-2013 02:08 PM
Recording from SC48 on new Macbooks without FW Tigerspill VENUE Live Sound Systems 5 09-28-2012 12:26 PM
SC48 recording jesseam VENUE Live Sound Systems 4 09-06-2012 03:09 AM
SC48 recording MikeP. VENUE Live Sound Systems 3 06-17-2012 01:04 AM
Recording from SC48 to MacBook Air Tigerspill VENUE Live Sound Systems 2 04-16-2012 04:31 PM
