Old 11-24-2010, 02:03 PM
trock trock is offline
Default Can i run HUI and Eucon at same time?
HI
I have the artist series controllers on PT 9, Mac Pro 10.6.5 and works great under eucon
i just bought for my ipad the v control from Neyrinck and it runs in HUI mode
just want to make sure i can run both in PT 9
thanks
tim
PT 10 - Mac Pro Octo 2.8 - 10.8.3
Artist series - MC control v2 - 2x mc mix - mc trans
Apogee Symphony
Old 11-24-2010, 03:46 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
Default Re: Can i run HUI and Eucon at same time?
HUI will mirror only the first bank of 8 faders loaded on your Ethernet controller.
Unless it has changed with Eucon support.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 11-24-2010, 04:55 PM
i just wanted to make sure i can set up both devices at the same time.
so i can set up the ipad controller with hui and the artist with eucon and have them both set up in PT 9 at the same time
thanks
Apogee Symphony
Old 11-24-2010, 05:58 PM
Bill Denton Bill Denton is offline
Artist_Series_and_Pro_Tools_Guide_r2_5_6.pdf - Page 6
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 11-25-2010, 04:31 PM
The golfer The golfer is offline
I think "Hui" does not work that well with the Eucon software 2.5.6 which is needed to control Pro-tools with eucon. I read in a recent post that some MC users went back to 2.5.5 to regain full "hui" fonctionality.
I installed v-monitor in about 5 minutes in our post studio which has no eucon software installed, but could not make it work in our music studio with the MC pro controller and Eucon 2.5.6.
I was able to assign "v-monitor" as a hui peripheral but the ipad would not recognize the Ney-fi network (wi-fi for v-monitor).
Anybody else has been successfull with eucon 2.5.6 and "HUI'?
Serge Hamel
Mixer / Sound Designer
http://www.netpostproduction.com
http://immersivesoundvr.com/
Old 12-03-2010, 08:29 AM
Hi tracks,
i finally had more time to run more tests and while I don't have the artist serie i can confirm that the euphonix system 5-mc With eucon works great with v-control.
Serge Hamel
Old 12-23-2010, 10:58 PM
Vedat's Avatar
Quiet Art Ltd.
I have tested Wave Rider (which uses HUI) with EUCON enabled MC MIX and the result is fantastic.
Eucon does not affect HUI operation at all, (unlike Digidesign ethernet controllers). HUI works fully independently alongside Eucon on PT9, well at least for Wave Rider .
So, either the manual needs updating, or I have a special case.
Vedat
QuietArt.co.nz
Catchin' SYNC app
Old 12-24-2010, 05:12 AM
macaholic macaholic is offline
Default
Wow Mundoz,
That's great news!! And probably tipped the scales for me considering getting a little MC setup at home, since I have two liscences for Waverider, one for work and one for home (got tired of moving iLoks back and forth, and wanted to support your company).
Works great on my D-Command setup and was holing out on Eucon for home because I thought I'd probably lose the use of Waverider.
Thanks for posting your results Mundoz.
JC
JC Richardson C.A.S.
Magick Lantern
Atlanta
[IMG] code is Off
Eucon Windows BUG: some windows r stuck in background when Eucon running. TuckerMix Artist Series 12 07-08-2014 01:37 PM
EUCon now connects less than 50% of the time! boomish69 Artist Series 12 01-29-2014 01:14 PM
Eucon 3 - have to reinstall each time to make it work. silverhammernz Artist Series 49 10-14-2013 10:33 AM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 12:01 PM
Alert - EuCon 2.5.6 is only for Pro Tools 9 and EuCon DigiTechSupt Artist Series 11 02-24-2011 10:25 PM
