Old 05-24-2019, 04:09 PM
pie55 pie55 is offline
Default 96 i/o with Behringer ada8000?
Hi
I'm using Protools 8.1.1 running @ 48 khz
Im trying to use a Behringer ada8000 with a 96 i/o via adat.
my main interface is a Lynx Aurora 16.
I've selected adat rather than aes/ebu in the hardware menu . My ada8000 has a word clock cable from the 96 i/o out and 96 i/o word clock is selected in the hardware menu.
but in the input of a channel the adat input reads "digilink N/A"
and in the i/o settings the optical are grayed out
anyone?
thanks
Old 05-24-2019, 04:34 PM
Default Re: 96 i/o with Behringer ada8000?
Can you describe exactly what is connected to what. Is the Lynx connected to DigiLink?
You have the Berribger ADAT output connected to the ADAT input on the 96IO?
What cards are in the 96IO?
Post screenshots of the 96IO setup pages.
Old 05-24-2019, 04:47 PM
If you disconnect everything else and just have the 96IO connected directly to your HD card does that work?
Old 05-24-2019, 04:50 PM
ah the bnc cable I was using is defective...
Old 05-24-2019, 06:03 PM
ah darn I thought it might be the Lynx eating DigiLink IO channels, but I could not remember how they get set up...
Behringer ADA8000 (BLA) JONK Pro Tools 9 14 03-14-2012 02:28 PM
Behringer ADA8000 kevinsimons 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-18-2006 12:06 AM
Behringer ADA8000 stevesound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 05-31-2004 01:40 PM
Behringer ada8000 hotstuff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-21-2003 07:01 PM
Behringer ADA8000 Punx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 10-17-2003 04:00 AM
