Old 12-15-2014, 08:21 AM
anackman's Avatar
anackman anackman is offline
Default Importing 24bit/48k into 32bit/48k session
Can a 24bit/48k file be imported into 32bit/48k session in Pro Tools without having pitch fluctuations or other oddities?
Both 48k, it's just the bit rate that is different.
Please help! Thanks so much.
MAC OS Ventura
Pro Tools 2024.3
2020 iMac 27" 3.2 Ghz i5, 64GB Ram
UA Apollo Rackmount Thunderbolt + Dangerous D-Box
2x Glyph Studio 2TB Raid SSD
Old 12-15-2014, 08:53 AM
Default Re: Importing 24bit/48k into 32bit/48k session
Sure, should be completely transparent (both from a workflow and audio perspective). Are you having a problem?
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 12-15-2014, 09:02 AM
anackman's Avatar
Hey Rich,
Thanks for your reply. A client sent me a vocal track to mix with a session I already have and it just sounds off key to me. I can't tell if they just sent me the wrong vocal file that was not comped/edited, or whether the issue is a bit-rate thing on my end.
Everything lines up perfectly, so I'm thinking my client just sent me a bad vocal take and meant to send me something else (hoping that's the case). Usually with bit/sample rate issues, the files don't line up on the grid the same way.
The vocal he sent is 24bit/48k, but the original session we were working in was 32float/48k.
MAC OS Ventura
Pro Tools 2024.3
Old 12-15-2014, 09:37 AM
mesaone mesaone is offline
the bit depth doesn't have any affect on speed or pitch, regardless of import method.
Maybe you can create a new session at 48 kHz 24 bit, then import an audition the file. I'll wager it sounds the same.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 12-15-2014, 01:36 PM
LDS LDS is offline
You can import any audio with a lower bit depth than the actual session without any issues in sound quality.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 12-15-2014, 01:57 PM
Bill Denton Bill Denton is offline
Hey Rich,
Perhaps one may exist that I'm not aware of, but last time I looked there weren't any widely available converters that support 32-bit.
Whatever is coming in to the session will be 24-bit, everything coming out of the session will be 24-bit...so everything inside the session will also be 24-bit...it will just be in a 32-bit box...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 12-15-2014, 03:56 PM
... it just sounds off key to me. ...
Well, whatever's wrong has nothing to do with bit depth.
Good luck!
rich
Recording: 24bit vs. 32bit float WombatStudio.Org Tips & Tricks 55 10-05-2014 03:41 PM
24Bit dithering in a 32Bit session. Any problems known? Franco1967 macOS 4 12-22-2011 12:50 AM
batch conversion 32bit to 24bit siga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-23-2007 04:51 PM
importing 16bit into 24bit session cliepe12 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-24-2004 09:39 AM
32bit.wav to 24bit sdII neuman Pro Tools TDM Systems (Mac) 0 05-08-2000 10:44 PM
