Old 10-29-2012, 05:25 PM
MFPBand MFPBand is offline
Default Default selection length
I have a McBook Pro running Pro Tools LE 8.0.3. When I create a new session, the selection markers are already set to just the first four bars. This is a problem because if no one remembers or notices that, only four bars get recorded. How do I change that back to zero bars (or infinite)?
Old 10-30-2012, 01:22 PM
JazzyJ JazzyJ is offline
Default Re: Default selection length
trash the PT preferences and start again.
Remember to re-enter no. of processors, buffer size and TCE after trashing.
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
Old 10-30-2012, 03:32 PM
Where is that file stored?
Old 10-30-2012, 04:09 PM
To trash Databases and Preferences on a Mac:
To trash your databases, you should delete the Digidesign Databases folder on each of your mounted hard drives, and then delete the “Volumes” folder that’s located in Macintosh HD > Library > Application Support > Digidesign > Databases.
To trash your preferences, go to Macintosh Hard Drive > Users > “Your User Name” > Library > Preferences. Delete anything that starts with “com.digidesign,” the “DAE Prefs” folder, “Pro Tools preferences,” and “DigiSetup.OSX”
or use the ProTools Prefs & Database Helper
http://www.jcdeshaies.com/
PT11 / OSX 10.8.5
Setting of 'Edit Window Default Length' critictalk Tips & Tricks 1 07-30-2013 10:39 PM
Crossfade default length kje Pro Tools TDM Systems (Mac) 6 11-10-2010 07:50 PM
Moving Selection By Selection Length weezerboy Pro Tools TDM Systems (Mac) 14 09-23-2010 03:06 AM
Edit window default length limit - why? trc229 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 09-21-2009 06:59 PM
change default fade length swpowe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-29-2006 01:26 PM
