Old 04-30-2011, 09:21 AM
machew machew is offline
Exclamation Video frames not advancing
On my version of pro tools Le 7 on my imac (mac os x 10.6.6, 3.2 GHz intel corei3, 4 GB 1333 MHz DDR3) I keep encountering the same problem when trying to work with video.
The video and sound will upload fine, but when trying to playback, as the curser advances, only the sound is played. The video will remain frozen at the frame where I decided to start the playback.
I tried uploading many different formats (from different sources as well) and I still can't figure this out.
Any help is greatly appreciated, Thanks.
Old 04-30-2011, 10:25 AM
BRH BRH is offline
Default Re: Video frames not advancing
I didn't think PTLE 7 works on intel mac and 10.6
Old 04-30-2011, 10:52 AM
lylesdonald lylesdonald is offline
PT7 will work on an Intel Mac but not with OSX 10.6 only 10.5. You should upgrade to PT 8 if you are able.
Old 04-30-2011, 02:37 PM
The version of pro tools I have works fine for audio, its really just for video it gives me problems. Ill try to upgrade to 8 to see if it will solve anything.
Old 04-30-2011, 04:01 PM
So I upgraded to 8 and its the same problem... The video is there but remains frozen on the first frame during playback.
Maybe there is something wrong with the video format. Can anyone give me a detailed description of the best configuration for a video to work in pro tools.
Thanks again
Old 05-02-2011, 09:34 AM
Old 05-02-2011, 01:54 PM
Craig F Craig F is offline
what codec is the video?
Thank you,
Craig
Old 05-02-2011, 02:14 PM
DV/DVCPRO - NTSC, Linear PCM, Timecode
I've also tried with different codecs but still no luck...
thanks
Old 05-06-2011, 12:42 PM
Video Capture aborted due to doppes frames abx992000 Pro Tools TDM Systems (Win) 0 06-02-2011 12:20 PM
No Video Frames????? mikevarela Post - Surround - Video 5 03-23-2008 11:28 PM
Anyone actually use frames mode on the video track? Starcrash Post - Surround - Video 14 04-16-2007 09:09 AM
a video brainteaser: frames and beats matching sidereal-studios Post - Surround - Video 10 05-12-2004 10:57 AM
video dropped frames in capture re-re-re visited Michael Klinger Pro Tools TDM Systems (Mac) 2 01-25-2002 01:09 PM
