Old 03-28-2011, 09:00 AM
mr.armadillo mr.armadillo is offline
Default using HDMI input mutes line audio input of TV
Here's the situation:
Blackmagic Intensity Pro going into TV (Sony Bravia) via HDMI. At the same time, we're sending audio to the TV via line-in (to monitor our mixes on crappy consumer speakers). This works fine if
a) the HDMI-cable is unplugged
b) we're sending signal from a Macbook Pro's mini-DVI to the TV via DVI-HDMI adapter.
But if the HDMI-cable which is going out from the Blackmagic card is plugged in, the TV seems to look for the audio stream in the signal and cuts the line input.
I thought to be very clever and tried to "strip" the audio part from the HDMI signal by converting it to DVI and then back to HDMI again, but alas, it didn't work out.
Does anyone have a solution for this problem?
Old 03-28-2011, 11:39 AM
BRH BRH is offline
Default Re: using HDMI input mutes line audio input of TV
Use RGB or y-rb anolog for the video into TV and then analog line audio.
If you use the HDMI for pic and anolog audio for sound.. chances are it'll be out of sync anyway.
kkfaudio kkfaudio is offline
You might want to check which HDMI input you're using.
On my Samsung, the line input is designed to be active only on a specific HDMI input, specifically for the DVI-HDMI type of situation you describe.
Hope that might help...
Kevin
Kevin Ferrier
Audio & Sound Design
www.jaxxcreative.com
Old 03-28-2011, 12:16 PM
Yeah, but then I won't get Full HD 1080!
That's why I use Syncheck to determine the video sync offset.
Old 03-28-2011, 12:19 PM
Kevin
Thanks, Kevin. There's only the "HDMI 1"-input on the Sony Bravia which allows for an additional analog audio in. It works with the Macbook Pro situation. It just doesn't want to work with the Blackmagic card.
Old 03-28-2011, 12:31 PM
thierryd thierryd is offline
on our Panasonic screens we choose a setting that selects HDMI audio or analog audio in. Maybe this exist on yours as well.
Cheers,
Thierry
http://www.a-sound.com/
Old 03-28-2011, 12:39 PM
Cheers,
Thierry
Thanks! Unfortunately, this option doesn't seem to exist on that TV. I spent hours reading the manual and checking the menu. Then again, I might be to stupid to find it.
Old 03-28-2011, 03:40 PM
minister's Avatar
minister minister is online now
Why not?
Component is fully capable of handling 1080. I am connected to a projector from an AJA Kona card component and it is stunning 1080p.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 03-28-2011, 04:08 PM
Originally Posted by minister View Post
Why not?
Hm. Actually, I wasn't aware of that! You're totally right. I was thinking because it's analog, it wouldn't work... Stupid me. Sorry, BHR!
This would've even saved us some money since we hooked up HDMI splitters to feed the talent's screens when the card is actually able to output both HDMI and Component at the same time.
So, there isn't any signal degradation going on compared to HDMI?
Another solution would be something like this:
http://www.cypconverters.com.au/othe...clux-11ca.html
Old 03-28-2011, 08:23 PM
ggegan ggegan is offline
Kevin
Thanks for that info! I've had this same issue with my 42" Samsung. Which HDMI input do you use to still allow line input?
Gary Gegan
HTML code is On
XLR mic input or TRS line input on mbox craig123 Pro Tools 10 4 03-05-2012 01:42 PM
Defaulting to Mic input instead of Line input... a2zproductions ICON & C|24 2 12-09-2006 01:41 PM
Track input line Mutes itself Automatically, Why? DarylBham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-06-2006 09:30 AM
THE LINE INPUT AND MIC XLR INPUT IN DIGI002RACK JOAN ROSALES 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-05-2003 01:26 PM
I/O LINE INPUT, I/O OPTICAL INPUT DIGI 002 RACK JOAN ROSALES 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-28-2003 04:08 PM
