Old 03-03-2011, 10:16 PM
Sam H Sam H is offline
Default Memory leak with EuControl on Win7 x64
Hi All,
After another post in the Steinberg forums mentioned the possibility of this - I had a look in task manager after working for a few hours today. Sure enough EuControl was using 1.07GB of memory after just 3 hours.
When I reboot - it starts off using about 30mb (which seems more like it!) - but then it creeps up. I didn't really get into trouble as I have 12gb and its running in 64bit address space - but if this issue exists on a 32bit system or I leave mine open a couple of days then there will be issues! And any GB of memory that is wasted cant be used for important stuff like loading more instruments if you are into that way of working....
Any DTS crew seen or know of this??
Cheers
Sam
Old 03-04-2011, 09:15 AM
collinsylex collinsylex is offline
Default Re: Memory leak with EuControl on Win7 x64
i just checked mine, its been up about 16 hours, its at 48114k memory usage...
no leak on my setup....
Old 03-04-2011, 09:27 AM
DigiTechSupt's Avatar
Let me look into this. I don't have any other reports that I recall.
Which DAW and version are you using? Which version of EuCon? Can you give us your system specs?
Avid Audio Tech Support
Support FAQ
Old 03-04-2011, 11:21 AM
johngar johngar is offline
I have tested this this on Cubase 6 as well as Pro Tools 9 on PC
Eucon 2.5.7.
The problem is the same for both.
Watching the EuControl.exe in windows task manager, whilst the transport is playing, the Memory value is "counting up" at the same rate about 40-50 bytes/sec. when you hit stop on the transport or you are not using the MC Transport or MC Control, just sitting there idle , the "counting up" stops
See my system specs below.
PC-Windows10 64bit - i7-4920 - 32gb ram - RME9632 -Nuendo 8 - ProTools 9 - MC Control - Mix - Transport
MAC- OSX - 10.10.5 - MOTU828MKII - ProTools9
Old 03-04-2011, 11:55 AM
Durcu Durcu is offline
The same problem here. EuControl 2.5.7 73168 (bmanager silverserver), more then 1 GB, and it grows...
Old 03-04-2011, 09:02 PM
System is a X3520, 12gb mem, UD5 running Win7 x64. Eucontrol is 2.5.7 x64. Nuendo 5.1.1 and PT9 running on RME AES32.
Old 03-07-2011, 03:39 PM
TAFKAT TAFKAT is offline
Some details of your system that is not displaying the issue would be helpful.
What Operating System : OSX 10.6 32Bit / 64Bit , Win7 x86 / Win7 x64 ?
What DAW Host ?
Vin Curigliano
AAVIM Technology
DAWbench.com
Old 03-08-2011, 03:30 AM
Any news here?
The memory usage accumulates as long as the transport is running, in both Nuendo5 and PT9.
If just the session is open and not playing it seems to stay normal...
Old 03-08-2011, 12:29 PM
Thanks for the reports - it appears there's something to this and we're investigating the source of the problem.
Support FAQ
Old 03-08-2011, 03:47 PM
Good to hear, Thanks...
Memory leak going 11.01>10.3.6 DetroitT Pro Tools 11 0 07-18-2013 04:42 AM
PT Memory Leak and Crash notedmusic Windows 5 03-16-2013 07:50 AM
Insert key non existent on EuControl (Win7) djmichaelwenz Artist Series 1 10-16-2012 10:36 PM
Memory leak in EuControl 2.5.7 DhyanMikael Artist Series 0 04-23-2011 07:13 AM
Memory Leak in 7.3? BlindDog Pro Tools M-Powered (Win) 2 01-15-2007 09:21 PM
