Re: PACEAP Driver Not Installing
cheers ill give it ago and give u a shout on how things go
well ive done everything u sed in the last post and its still comeing up with
"this software requires intstallation of the InterLok(R) drivers" dialogue box |
when you go to the ilok.com site with your inserted does your ilok sync properly??? you should show Pace, iLok, and License Support software installations in control panel/programs. i'm not in the studio to give you exact verbage and revisions but you should see 'em listed...
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
Ive got Ilok Client helper and Interlok driver setup x64 but no license Support in my control panel/programs, and ilok.com does regonise my ilok
but i know where the License support.msi is but not the actuall installtion.exe for that :/ |
then that's your problem...you gotta have the License Support Software installed for PT9 to run. i understand that you followed the steps i suggested. but unfortunately i have no idea what you did, installation wise, before you tried my steps. again, that is likely what messed up your process. and one can really work themselves into a maze if certain steps are NOT followed on the INITIAL install. so my only suggestion right now is, some kinda way get the License Support Software installed. don't know how to tell you how since it 'should' install with PT or the drivers (can't remember which one tho...but it is part of the overall installation process) so...hopefully this helps ya
#16
Please advise? |
#17
Aaron Mulqueen - 001 HD Native |
#18
thats for the help Mkhal C, if u do happen to think of a way let us know
@Filosofem - the date of the new one is 30 march 2011, but as mention in the previous post the driver setup for some reason keeps crashing on me when i try to install that particular driver :/ |
#19
Can you post a Sandra Report please? Did you have any problems downloading any of those drivers whether iLok Client Helper or PACEDriver?
#20
No problems at all downloading them. the Ilok Client (+ pace driver it comes with) installed fine, but when installing the PACEDriver itself; it just keeps crashing.
anyway heres the report...... SiSoftware Sandra Computer Model : Packard Bell ixtreme M3720 Workgroup : WORKGROUP Host Name : daz-PC User : daz Processor Model : Intel(R) Core(TM)2 Quad CPU Q8300 @ 2.50GHz Speed : 2.5GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing Computer Mainboard : Packard Bell MCP73PVT-PM BIOS : AMI P01-A3 07/21/2009 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 4GB DIMM DDR2 Chipset Model : Acer MCP73 Host Bridge Front Side Bus Speed : 4x 333MHz (1.33GHz) Total Memory : 4GB DIMM DDR2 Memory Bus Speed : 2x 400MHz (800MHz) Memory Module(s) Memory Module : GU342G0ALEPR692C6F 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : GU342G0ALEPR692C6F 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Video System Video Adapter : NVIDIA GeForce 210 (16 SM4.1 1.4GHz, 512MB DDR2 128-bit, PCIe 2.00 x16) Video Adapter : NVIDIA GeForce 210 (16 SM4.1 1.4GHz, 512MB DDR2 128-bit, PCIe 2.00 x16) Graphics Processor OpenCL Processor : NVIDIA GeForce 210 (16SP 2C 1.4GHz, 512MB DDR2 128-bit) Compute Shader Processor : NVIDIA GeForce 210 (16SP 1.4GHz, 512MB DDR2 128-bit) CUDA Processor : NVIDIA GeForce 210 (16SP 2C 1.4GHz, 512MB DDR2 128-bit) Storage Devices WDC WD6400AAKS-22A7B2 (640.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 596GB (C:) (D:) SAMSUNG HD204UI (2TB, SATA300, 3.5", 5400rpm, 32MB Cache) : 2TB (N:) Generic-Compact Flash (USB) : N/A (G:) Generic-xD-Picture (USB) : N/A (H:) Generic-SD/MMC (USB) : N/A (I:) Generic-MS/MS-Pro/HG (USB) : N/A (J:) Generic-MicroSD (USB) : N/A (P:) ATAPI DVD A DH16AASH (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 7GB (E:) Disk : 2GB (M:) FSBAD TIR4P6NK9 (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (Q:) Logical Storage Devices SYSTEM RESERVED : 100MB (NTFS) Music (N:) : 2TB (NTFS) @ SAMSUNG HD204UI (2TB, SATA300, 3.5", 5400rpm, 32MB Cache) Packard Bell (C:) : 290GB (NTFS) @ WDC WD6400AAKS-22A7B2 (640.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) DATA (D:) : 291GB (NTFS) @ WDC WD6400AAKS-22A7B2 (640.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) PQSERVICE : 15GB (NTFS) Removable Drive (G:) : N/A @ Generic-Compact Flash (USB) Removable Drive (H:) : N/A @ Generic-xD-Picture (USB) Removable Drive (I:) : N/A @ Generic-SD/MMC (USB) Removable Drive (J:) : N/A @ Generic-MS/MS-Pro/HG (USB) Removable Drive (P:) : N/A @ Generic-MicroSD (USB) Pro Tools (E:) : 7GB (CDFS) @ ATAPI DVD A DH16AASH (SATA150, DVD+-RW, CD-RW, 2MB Cache) KB3AIK_EN (M:) : 2GB (UDF) @ Disk Optical Drive (Q:) : N/A @ FSBAD TIR4P6NK9 (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) Peripherals LPC Hub Controller 1 : Acer MCP73 LPC Bridge LPC Legacy Controller 1 : ITE IT8718F Audio Device : Acer MCP73 High Definition Audio Audio Codec : Realtek Semi 888 High Definition Audio Audio Codec : nVidia 8001h Audio Device : 6510 High Definition Audio Controller Audio Codec : nVidia 000Bh Audio Codec : nVidia 000Bh Audio Codec : nVidia 000Bh Disk Controller : Acer MCP73 IDE Disk Controller : Acer GeForce 7100/nForce 630i USB Controller 1 : Acer GeForce 7100/nForce 630i USB Controller 2 : Acer GeForce 7100/nForce 630i SMBus/i2c Controller 1 : nVidia MCP5+ SMBus 1 SMBus/i2c Controller 2 : nVidia MCP5+ SMBus 2 Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP PSC 1500 series (1200x1200, USB, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Canon MP220 series Printer (USB, Colour) Peripherals Network Services Network Adapter : Realtek PCIe FE Family Controller (Ethernet, 10Mbps) Network Adapter : VMware Virtual Ethernet Adapter for VMnet1 (Ethernet, 100Mbps) Network Adapter : VMware Virtual Ethernet Adapter for VMnet8 (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 2.8 |
DigiHFS not installing (HFS+ Driver) | corthreat | Windows | 0 | 08-23-2012 01:12 PM |
installing M-Audio Driver | Sir Les | Pro Tools M-Powered (Win) | 1 | 06-06-2007 01:34 AM |
Driver problem when installing PT7? | bcu11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-25-2005 10:30 PM |
Installing Motor Mix driver fr LE 6.4 CD:where to? | Tubthumper | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-08-2004 05:03 PM |
help installing driver on macg4!!!!!!!!! | KemikAL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-27-2002 10:26 PM |
