Old 08-31-2002, 08:07 PM
R SCHLESINGER R SCHLESINGER is offline
Default Cleaning Faders and Pots
In response to a few phone calls. Do not use WD-40 for cleaning faders, pots, or switches, with the C-24 or anything else. When cleaning any fader, do not use a solvent and just spray it in. You will damage the fader. For Penny & Giles faders, they recommend,"A mild soap like Ivory and warm water."(You also have to take the fader apart.)
A potentiometer can only be cleaned if it is not sealed. The type of material used for the pot determines what to use for cleaning. Sometimes merely exercising the pot will solve the problem.
If your c24 (or any other console) needs to be cleaned, you should have a tech or the manufacturer do it.
RADAR
Calibrating Trim Pots, Pots not responding D-Street Pro Tools TDM Systems (Mac) 9 09-04-2010 10:01 AM
pan pots ec123 ProControl, Control|24, Command|8 1 09-19-2009 01:42 AM
Frozen Pan Pots and Faders!Please assist barismanco123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-23-2009 02:45 PM
Cleaning the Pots? jimbojimbo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 04-19-2008 02:28 AM
Pot and DSP pots Charles Deenen ProControl, Control|24, Command|8 0 03-27-2001 06:31 AM
