Control 24 PSU replacement instructions
Dear Avid or anyone:
My Control 24 power supply is behaving as Kenny Gioia described in the thread called "Blown Capacitor on the PSU Control 24", so I need to remove the PSU and return it to Avid for a $350 fix. Before I deconstruct my desk and open up the back panel, does anyone happen to have a schematic or tip sheet on pulling the PSU? |
Re: Control 24 PSU replacement instructions
Here it is: http://sn.im/1s5or9-by4
Pro Tools Tutorials: Mixing Heavy Rock & Metal Pro Tools 11 - Tips and Tricks Delay Explained Tracking Rock - Drums Mixing Rock Music Production with Pro Tools Pro Tools Tips and Tricks Vol. 2 Pro Tools Tips and Tricks Vol. 3 Elastic Audio in Action |
Thanks a lot for taking the time to find that, Kenny.
Yes, they'll fix it for $350 or replace it for $500. But first I'm going to swap out the capacitor at location C20, which someone over at gearslutz claims is the one that overheats. The C20 capacitor in my Rev H PSU is already rated for 105C, which is the highest temp rating I can find for a 4.7 MFD 50V capacitor, but I figure it's worth the ten minutes and ten cents to see if it gets me back on the road today (or tomorrow). Thanks again for the pdf. |
Good luck.
No dice.
I've replaced the C20 cap and have the same symptoms as before. Back to Avid she goes. Thanks for your help. |
Good luck with it.
My problem was fixed but now I think it's time to do the cleaning of the connectors. She likes to give me a light show every once in a while. heh
Yes, the annual Cleaning of the Connectors. And don't forget to floss.
I thought I'd reseat this thing one more time before sending it off, and now it works. Which of course sucks.
For the record, C20 was probably okay before I replaced it. Now that it's out of the board, I've tested it with an ohmmeter and it's holding and releasing charge. Someday I'll borrow a cap meter and test it properly. I'm thinking of buying in a replacement PSU to stick in the closet. If I do, I know the board will never fail. If I don't, I'm sure it will throw a clanger as soon as it's least convenient. Good luck with your cleaning. If it continues to act out you should think about repurposing it as a 2-for-1 live console with light show capabilities. |
That's weird. So it never was the capacitor.
But it was blinking and making a pulse sound? Mine seems to be perfect for the last two days so I haven't got around to cleaning it yet. I hate the idea of fixing something when it's not displaying the symptoms as I won't know if I fixed anything. Good luck.
Yeah, I know. Maybe caps don't always "die", maybe they get "tired". That would explain the intermittent behavior.
I had a choice of two different manufacturers for the replacement I used, and they're rated at either 1000 or 2000 hours lifetime at max temp (105C), which isn't a whole lot of time. I'll try harder now to remember to turn it off overnight. And yeah, the symptoms you described in your "Blown Capacitor..." thread were exactly what I was seeing. Who knows. Back to the good stuff. |
A simple replacement for Control 24 | Matt Phat | Getting Started | 5 | 07-05-2013 12:25 PM |
Need take-apart instructions for Control|24 | rockwald | ICON & C|24 | 0 | 09-17-2012 04:06 PM |
PSU, Monitor Board and Fader replacement instructions? | Armando | ICON & C|24 | 36 | 01-14-2012 09:49 AM |
Where can I find PT LE Laptop control instructions for a Macbook Pro? | JAZZ27 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-08-2009 04:48 AM |
Instructions regarding how to get the Control 24 recognized | Rule62 | ICON & C|24 | 2 | 07-12-2007 01:30 AM |
