Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 06-15-2013, 02:58 AM
Tanno Buchino Tanno Buchino is offline
Default Double problem - M-Audio Fast Track Ultra 8R
Hello,
As it's been stated, I have double problem, which I'll explain as following...
1) The driver of this card CAN'T be updated to the newest, and the UI reads the WRONG OS. I'm using Win 7 64bit SP1, NOT sVista SP1. It can be shown to the following picture as proof.
2) Until Thursday I didn't have lag problems. Since I restarted the PC, and for unknown reason it started having lag of 8secs. Like this, I can't concentrate on working my music production, nor can hear any music to any youtube stuff. There's also that weird clipping preventing it to smoothly be heard. It can be shown as proof in the following picture.
Any help would be appreciated to fix this madness. For the time being, untill any fix can be present I have disabled this very USB.
Thanks
Old 06-17-2013, 05:54 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Double problem - M-Audio Fast Track Ultra 8R
What errors do you get when trying to update the driver? I don't think the OS being reported incorrectly is going to cause any issues, and might be fixed if you can get the newer driver installed.
What do you have your buffer set to? Any software/hardware changes to your system around when it started acting up?
Please go through this post and post back:http://duc.avid.com/showthread.php?t=336556
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 06-17-2013, 01:11 PM
That's the problem. Althought it has been installed alright, the driver's being still at this 5.10.5.5100(as noticed in this picture). Literally, it DOESN'T update to the newer(6.0.8) as I found in this very site. It's got stuck there.
The buffer is set to 256. In which buffer do you suggest me to change to find a possible fix?
Yeah, the whole PC has acted, because of it. Youtube frequently stopped and the sound clipped as the lag suggests. Same goes for every program(Windows Media Player, VLC, etc).
Even the Cubase SX 6, which I'm working a project currently, lags. When I play a project, it lags to 8ms, and there's that weird echo sound echoing from this very card. It was also noticed from Cubase SX6's main output source monitor.
Computer model: The small ones from the home computers(if he meant that), otherwise Asrock Z77 Extreme M-4.
Processor speed: Intel® Core™ i7-3770 CPU @ 3.50GHz
OS: Windows 7
M-Audio hardware model: M-Audio Fast Track Ultra 8R
Pro Tools: None, I'm unknowledged with Pro-Tools programs.
RAM: 8GB
A complete and precise description of any attached peripherals (hard drives, video devices, other firewire or USB devices that may be attached, etc). We need to know to which port on the computer they're connected to, what type of cables you're using (is it a FW800-FW400 adapter cable? How long is it? Are you using an extender or repeater?) and, if you've tried replacing cables, what the differences were between the original and the replacement.: I'm no expert, but I have 2 external hard drives and they're as usual USB-deviced connected with a USB merger(you guys know what do I mean) onto a single USB port. I'm against to the mess, so I tend to be tidy. No other cables are inserted than these.
Number and type (firewire, SATA, SCSI, etc) of drives installed, how they're formatted and which one(s) you're using for recording and playback.: I'm unsure if it helps, but I have only 2 SATA external drivers as mentioned above. The internal driver is SATA 3(I think) and this is where I have installed Cubase projects and the Cubase itself to avoid any misuse to the basic driver.
A concise list of the troubleshooting you've already tried - please be as specific as possible! The first thing we'll ask is 'Have you done everything in the Setup and General Troubleshooting thread?', so we'll want to know that you've done ALL of it and, if you've not done everything, we need to know what you have or have not done, as this can have a huge impact on further troubleshooting.: My first time doing so, so hit the list of troubleshooting to find out any solution to this. Otherwise, I'd not be here asking for help. lol
Sandra Report
SiSoftware Sandra
ID
Host Name : Owner-PC
Workgroup : WORKGROUP
Computer
Model : OEM
Serial Number : To Be Fille***********
Chassis : Desktop
Mainboard : ASRock Z77 Extreme4-M
Serial Number : M80-2C0********
BIOS : AMI (OEM) P1.50 12/10/2012
Intel vPro : 8.01.00.1248
Total Memory : 7.89GB DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz (4C 8T 3.9GHz, 3.9GHz IMC, 4x 256kB L2, 8MB L3)
Socket/Slot : FC LGA1155
Chipset
Memory Controller : ASRock Core (Ivy Bridge) DRAM Controller 100MHz, 8GB DIMM DDR3 1.33GHz 64-bit
Memory Module(s)
Memory Module : Kingston KHX1600C9D34GX 4GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5)
Video System
Monitor/Panel : Samsung S27B350
(1920x1080, 33.1")
Video Adapter : NVIDIA GeForce GTX 550 Ti (4CU 192SP SM5.0 1.8GHz, 384kB L2, 1GB 4.1GHz 192-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA GeForce GTX 550 Ti (192SP 4C 1.8GHz, 384kB L2, 1GB 4.1GHz 192-bit)
Compute Shader Processor : NVIDIA GeForce GTX 550 Ti (192SP 4C 1.8GHz, 384kB L2, 1GB 4.1GHz 192-bit)
Compute Shader Processor : Intel(R) HD Graphics 4000 (128SP 16C 350MHz/1.15GHz, 64MB DDR3 1.33GHz 64-bit, Integrated Graphics)
CUDA GP Processor : NVIDIA GeForce GTX 550 Ti (192SP 4C 1.8GHz, 384kB L2, 1GB 4.1GHz 192-bit)
Storage Devices
WDC WD10EZEX-00KUWA0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (C:) (D:)
Generic USB SD Reader (USB2) : N/A (F:)
Generic USB CF Reader (USB2) : N/A (J:)
Generic USB SM Reader (USB2) : N/A (K:)
Generic USB MS Reader (USB2) : N/A (L:)
WDC WD10EARS-00Y5B1 (1TB, USB2/SATA300, 3.5") : 932GB (H:)
Seagate ST2000DM001-9YN164 (2TB, USB2/SATA600, 7200rpm) : 2TB (I:)
DTSOFT BDROM () : N/A (G:)
Logical Storage Devices
Linked to the System : 100MB (NTFS)
Ritmo 1TB (H:) : 932GB (NTFS) @ WDC WD10EARS-00Y5B1 (1TB, USB2/SATA300, 3.5")
Expansion Drive (I:) : 2TB (NTFS) @ Seagate ST2000DM001-9YN164 (2TB, USB2/SATA600, 7200rpm)
Windows (C:) : 248GB (NTFS) @ WDC WD10EZEX-00KUWA0 (1TB, SATA600, 3.5", 7200rpm)
Files (D:) : 684GB (NTFS) @ WDC WD10EZEX-00KUWA0 (1TB, SATA600, 3.5", 7200rpm)
Removable Drive (F:) : N/A @ Generic USB SD Reader (USB2)
Removable Drive (J:) : N/A @ Generic USB CF Reader (USB2)
Removable Drive (K:) : N/A @ Generic USB SM Reader (USB2)
Removable Drive (L:) : N/A @ Generic USB MS Reader (USB2)
Optical Drive (G:) : N/A @ DTSOFT BDROM ()
Peripherals
LPC Hub Controller 1 : ASRock Panther Point LPC Controller
LPC Legacy Controller 1 : T0 C3-33
Audio Device : ASRock Panther Point High Definition Audio Controller
Audio Device : CardExpert Tech GF116 High Definition Audio Controller
Audio Codec : nVidia 0015
Audio Codec : 1 0001
Serial Port(s) : 1
Parallel Port(s) : 1
Disk Controller : ASRock Panther Point 6 port SATA AHCI Controller
Disk Controller : ASRock Asmedia 106x SATA Controller
USB Controller 1 : ASRock Panther Point USB xHCI Host Controller
USB Controller 2 : ASRock Panther Point USB Enhanced Host Controller #2
USB Controller 3 : ASRock Panther Point USB Enhanced Host Controller #1
SMBus/i2c Controller 1 : Intel ICH SMBus
Peripherals
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps)
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
All set. I hope it helps.
Last edited by Tanno Buchino; 06-19-2013 at 10:04 PM. Reason: edit 1: Sandra Report just added. edit 2: Just noticed the Greek phrase "Δεσμευμένο από το σύστη
Old 06-27-2013, 12:22 PM
Fixed the lag problem. It needed TOTAL unistallation and UNPLUGGING the USB hardware from the PC. Once you plug the USB back and you install 6.1.8(Win7) drivers, it's being fixed! :)
Old 09-10-2013, 01:07 AM
The nightmare is back.
I tried formatting the PC to see if the clipping insisted. It still insists. Now I'm trying the backwards installation to find which driver isn't problematic to my system.
Once I see that this problem stops, I'll report it back to you.
BTW, I tried it in my Macbook and it was OK. The problem insists with the PC with Windows 7. Any dev would be kind to see it, because it makes me go nuts?
Old 07-26-2014, 09:09 AM
Green Room Green Room is offline
I have the same problems described in this post and even with the latest driver update 6.1.9 nothing has been solved!
Win 7 64 | Fast Track Ultra 8R
I just bought the card and I am unable to work!
At this time anyone has managed to solve the problem?
Old 07-28-2014, 07:19 PM
DC-Choppah's Avatar
DC-Choppah DC-Choppah is offline
I am using this interface with Windows 7 84 bit right now.
You must NOT set the Ultra 8r as the default audio interface in windows.Set your motherboard audio interface as the default in Windows and let your DAW only use the Ultra 8r.
DC-Choppah's Project Studio:
ASUS PRIME Z390-A / Intel i7 rackmount PC
Windows 10 home 64 bit
Pro-Tools 11.3.1
AIR Instrument Expansion Pack v2
WAVES Platinum plugin bundle
Tascam US-16x08 Interface
100% Analog real time monitoring 16x4
Yamaha 16 channel MG16XU Analog Monitor Mixer
Yamaha MX-88 / Novation XiO keyboards
Mackie 4-channel headphone amp
Adam A8X monitors
Blue / Shure, etc. microphones
Estonia 6' 8" Parlor Grand Piano
Yamaha Studio Drum kit
https://www.dc-choppah.com/
Old 08-27-2014, 12:44 PM
Juca Nascimento Juca Nascimento is offline
As I know, the USB drivers need to be installed with the device unconnected of the USB port. If you installed the driver with the device conected to the USB port, then:
1- With the device connected, uninstall the driver;
2- Disconnect the device from the USB port and install the new driver;
3- When the install finish, connect the device to the USB port, wait the automatic procedure of the installerto finish and test your device.
Sorry my bad English, my main language is Portuguese (brazilian).
Greetings.
Old 08-29-2014, 12:06 PM
Emcha_audio's Avatar
This actually is not the right info to give. In the bios, if you have any onboard audio chip set, you should disable them.
In windows go to start-control panel-sound- playback. Set the audio device to your interface, make sure it is the one that is set to default then click properties and in the advanced tab make sure the settings are the same as you are using on your interface. If for example your interface is set to 24 bit 96khz, that is what you have to set in windows. Now in the recording tab, make sure it is also the default then click on properties and in the advanced tab select the right numbers of input with the right bitrate and frequencies, for example if your interface has 8 input and you are recording at 24 bit 96khz, you will select that in the drop down menu. In the sound tab, disable all the windows sound.
Also if you're using cubase and windows to play other application, you might want to try asio4all, but the above about setting the right playback, record and sound tab should still be done.
Manny.
Wave-T.com
Old 09-01-2014, 04:11 PM
DC-Choppah's Avatar
Unfortunately, that still leads to problems with a clash of settings in some situations.
Pro-Tools 11.3.1
Adam A8X monitors
M-Audio Fast Track Ultra Help! Szenasi FireWire & USB Audio Interfaces (Win) 2 05-26-2013 11:55 AM
5.1 with M-Audio Fast Track Ultra 8R Elby Post - Surround - Video 3 05-25-2012 08:43 AM
Pro Tools LE and M-audio Fast track Ultra howbotnik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-16-2011 02:56 PM
M-Powered 7.4 and M-Audio Fast Track Ultra taveren93hgk Pro Tools M-Powered (Win) 3 04-29-2009 10:21 AM
Fast Track Ultra problem drhum23 Pro Tools M-Powered (Win) 1 08-01-2008 11:56 AM
