#5771
Re: i7 Builds - Specs and Results
CME,,, I've gotta check out that 12 core! But I can only guess that the cost might put me in the dog house. Hmmm,,, wonder how the acoustics are out there??
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 | |
#5772
So,, I saw this earlier, Crucial M550 CT512M550SSD1 2.5" 512GB SATA 6Gbps MLC Internal Solid State Drive (SSD). The Samsung #'s are similar, except for being SATA 3 Gbps. Is having a SATA 6 Gbps probably faster, or not so much? The price on each is also close.
Thanks,,, Mike
#5773
I think you may be getting confused a little. I bet the Samsung SSD is also 6gbps. Which is sata 3. Someone really wasn't thinking when they named these things. Basically sata 1 is 1.5 gbps, sata 2 is 3 gbps, and sata 3 is 6 gbps. And IMO a SSD for a system drive is totally worth it. I bought my first several years ago and will now always have an SSD for the boot drive.
And yes pt will see all the cores. Even the virtual cores that most CPUs have these days. So that 12 core would show up as 24. And when I upgraded my Mac Pro from a 2.66 quad to 3.2 6-core I saw a big difference in performance. I could push the quad a bit. Not a whole lot bu could make it begin to sweat. The 6-core handled everything I threw at it with ease.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
#5774
Thanks CME, that's whole lot clearer, makes sense. Almost 'glad' that I fried my board.?!
Mike
#5775
Finally decided to update my system. Great thread here with a lot of info. This is a first time build for me and I'm looking forward to it. Goal is to build a robust system with headroom and a fairly good life span expectancy. Probably will move to Win 8.1 for OS.
Pretty close to pulling the trigger on following: Intel Core i7-4930K http://www.newegg.com/Product/Product.aspx?Item=N82E16819116939 ASUS X79 DELUXE http://www.newegg.com/Product/Product.aspx?Item=N82E16813132047 SeaSonic SS-750KM3 – http://www.newegg.com/Product/Product.aspx?Item=N82E16817151087 Fractal Design Define R4 http://www.newegg.com/Product/Product.aspx?Item=N82E16811352037 Asus GT640-DCSL-2GD3 GeForce GT 640 Graphic Card http://www.newegg.com/Product/Product.aspx?Item=N82E16814121706 Noctua NH-U12S http://www.newegg.com/Product/Product.aspx?Item=N82E16835608040 SAMSUNG 840 Pro MZ-7PD256BW - http://www.newegg.com/Product/Product.aspx?Item=N82E16820147193 G.SKILL Ripjaws Z Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL8Q-16GBZM http://www.newegg.com/Product/Product.aspx?Item=N82E16820231539 DDR3 1866 (PC3 14900) Timing 8-9-9-24 Cas Latency 8 Voltage 1.5V ASUS DVD Burner SATA Model DRW-24B3ST/BLK/G/AS http://www.newegg.com/Product/Product.aspx?Item=N82E16827135240 Total around $1,950 with Win 8.1 Pro 64. I'll do some light overclocking but nothing to serious. Not sure if water cooling is really needed but a bit of overkill there won’t hurt, just don’t want to end up with too much noise. I’ll add an SSD for system drive and have several WD Black drives for audio, samples etc. Running an RME UFX via USB2. Sessions can get fairly large, up to 60+ tracks, plenty of plugins and fair VI usage. I’ve been researching ASUS docs for the X79 Deluxe for compatible memory and was wondering if there is any way to easily narrow down for price/performance ratio. Anybody used the i7-4930/X79 Deluxe combination successfully? Thoughts, cautions etc?
I7-4930K, X79-Deluxe, 2133 32 GB, GT640, 512GB 860 Pro, 1TB Evo, WDB 2TB X2, Win 10 Pro, PT Ultimate 2020.12 Studio One 5 Pro, REAPER 6 RME, Daking, Heritage, ISA, Sytek Last edited by WKG; 05-22-2014 at 01:16 PM. Reason: Revised... |
#5776
ASUS docs really don't make it easy to find compatible memory for the X79 Deluxe. Need to mind the budget and 16GB memory would probably meet my needs easily. Wanted to go for DDR3 2133 but I am thinking the difference in price/performance wouldn't justify the cost and there are a few other items I'd like to squeeze into the budget
A couple of options: G.SKILL Ripjaws Z Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL8Q-16GBZM $189.99 Cas Latency: 8 Voltage: 1.5V Multi-channel Kit: Quad Channel Kit Timing: 8-9-9-24 CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model CMZ16GX3M4X1866C9 $179.99 Cas Latency: 9 Voltage: 1.5V Multi-channel Kit: Quad Channel Kit Timing: 9-10-9-27 G.SKILL Ripjaws Z Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9Q-16GBZL $154.99 Cas Latency: 9 Voltage: 1.5V Multi-channel Kit: Quad Channel Kit Timing: 9-10-9-28
I7-4930K, X79-Deluxe, 2133 32 GB, GT640, 512GB 860 Pro, 1TB Evo, WDB 2TB X2, Win 10 Pro, PT Ultimate 2020.12 Studio One 5 Pro, REAPER 6 RME, Daking, Heritage, ISA, Sytek Last edited by WKG; 05-21-2014 at 10:36 PM. Reason: revised... |
#5777
Pretty much settled on the GSKILL 1866 with the lower latency.
If any of you guys with a bit more PT build experience than I could take a quick look at my revised build list two posts above I would appreciate it. I am pretty sure component wise but as I indicated it's a first build here.
I7-4930K, X79-Deluxe, 2133 32 GB, GT640, 512GB 860 Pro, 1TB Evo, WDB 2TB X2, Win 10 Pro, PT Ultimate 2020.12 Studio One 5 Pro, REAPER 6 RME, Daking, Heritage, ISA, Sytek |
#5778
I don't personally have any experience with SeaSonic, so if I was shopping then I would go with a Corsair or CoolerMaster 750 W modular PSU. Otherwise, Almost exactly the build I would do, if I could do one now. Excellent case, fast and reliable RAM, good SSD, RME interface, screaming 6-core CPU.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB Last edited by mesaone; 05-22-2014 at 03:11 PM. Reason: Spacial is spelled incorrectly |
#5779
Next to RAM finding an effective cooler is a pain. I am trying to balance efficiency with noise level as the computer is in the same room I record in. Hopefully the "screaming 6 core" won't bleed into the mics...
#5780
That noctua cooler is probably the quietest on the market for the CFM. A mistake I made is going for liquid cooling. The problem with using radiators is that the fans are closer to the outside of the case, and end up being quite loud. A noctua cooler paired with that fractal case should keep your computer whisper-quiet, even with a 6-core.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 07:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 07:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 12:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 08:37 AM |
