Old 03-18-2024, 05:39 AM
crizdee's Avatar
crizdee crizdee is offline
Default Adjusting contrast on fader pack?
Just realized as i went to adjust the contrast on the D command that the fader pack doesn't get adjusted
The brightness adjust OK across the main unit and the fader pack but not the contrast.
This is on PT10 Mavericks. console utility>prefs>contrast
Anyone know a way to adjust the contrast? or have any info on this?
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-18-2024, 03:12 PM
Led Led is offline
Default Re: Adjusting contrast on fader pack?
Not this specifically, but I had an issue where all the displays on my fader pack went really high contrast and I couldn't read them. In the page where contrast is in the utility menu there is an 'invert' button, clicking this to invert then again to go back to normal fixed the issue.
Old 03-21-2024, 05:49 PM
crizdee's Avatar
Interesting never knew this. so you can have every other channel inverted or groups of 4 inverted 4 not inverted or all inverted.
Just tried it but it doesn't seem to stick? exit by pressing OK and it reverts back to normal. thought it would stick
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-21-2024, 07:04 PM
Led Led is offline
Yeah not sure.. I only found it when I was randomly pressing buttons in a panic after my fader pack displays went dodgy
FS: Procontrol Main, 2 Fader pack and Edit Pack drogan88 Buy & Sell 0 07-12-2016 07:43 AM
FS: Pro Control Edit Pack and one Fader Pack antonis Buy & Sell 3 01-18-2016 11:40 PM
HELP! Edit Pack thinks its a Fader Pack! digitaltoast ProControl, Control|24, Command|8 1 01-27-2012 03:48 AM
Is Procontrol/edit pack/ fader pack still supported vudoo Pro Tools 9 8 11-06-2010 08:19 PM
Adjusting fader/rec/sel/sol In midi track problem junkgem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-23-2006 06:42 PM
