Old 01-28-2024, 08:36 AM
BWV846 BWV846 is offline
Default Playcell Missing bus mappings
Hi
Running PT Artist 2023.12, I have just downloaded and installed Playcell.
I find it in the recall inserts (what they are, I don't know. I don't see anything in chapter 51 about inserts of this type, and when I hit load insert, I get the following message:
Bus "MacBook Pro Speakers 1-2" could not be mapped to output "MacBook Pro Speakers 1-2"
and a link to open the I/O settings. I'm running Windows 11. I dont see anything about MacBook Speakers in the I/O Settings.
I don't see this result listed in Google anywhere; must be an uncommon fault. Any ideas please?
Regards
Old 01-28-2024, 10:03 AM
tope d's Avatar
tope d tope d is offline
Default Re: Playcell Missing bus mappings
Originally Posted by BWV846 View Post
Hi
Regards
Hi there,
I've started a support case regarding your concern. You'll be contacted by the support team via Email through case number 04748540.
Thank you
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 01-29-2024, 06:13 AM
Much appreciated; note I am on Windows 10 Pro 64 bit, not 11, as I mistakenly wrote above.
Parameter mappings EuCon, pim, XML? oortone AAX Plug-ins 0 11-23-2023 03:36 AM
"PlayCell Palette install failed" trying to install PlayCell 2023.3 Dizzi45Z Virtual Instruments 3 03-28-2023 12:40 PM
Share your Top 5 custom mappings: freeBase Avid S1, S3, Dock and Control App 1 06-14-2020 09:07 PM
FR - AIR instrument MIDI mappings remute Virtual Instruments 13 01-10-2009 09:44 AM
fader mappings pleasedonthitme MIDI 0 05-02-2003 09:25 PM
