Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 01-12-2024, 10:22 AM
Barbershop Barbershop is offline
Default Fast Track Solo
Okay, so I am using an older Fast Track Solo with Pro Tools Express 10.3.4 on an older Mac Mini still using 10.11.6 OS X El Capitan.
I felt like my mic input might be going bad because it wasn't getting a great signal. I had both pro tools and garageband open, and I plugged in another fast track solo that my friend had. I was just trying to test out the mic input, and something popped up (on Garageband) asking if I wanted to change it, so I said yes.
There was no sound when I played it. No sound on the new Fast Track so I chalked it up, and went back to my old one.
Now there is no sound on that one?
Is there anyway to fix this? I've read that it might be the drivers, but it was working fine just two hours ago, so why would that be the issue?
I've restarted and tried to do things of that nature.
Any idea how I can fix this?
And yes, I know I am on a dated system, an old version of PT, and an old interface, but I have been using it like this for 10 years and I like the setup.
Any help would be awesome.
Thanks!
Old 01-12-2024, 01:25 PM
Default Re: Fast Track Solo
update
okay so now I am even more mind blown
So I pulled out my laptop, and it has the same pro tools express, and I use the same Fast Track Solo on it, and now it doesn't work either...
So it can't be the drivers.
But how did an interface like this just stop working?
Pro Tools works, it opens, and I can edit, and it plays, but there is no sound.
My mind is blown.
Old 01-14-2024, 09:50 PM
basslik's Avatar
basslik basslik is offline
Originally Posted by Barbershop View Post
update
My mind is blown.
Reboot Mac. hold down the (N) key while starting up pro Tools then it should give you an option to select sound device.
But first make sure the mic is working first on a mixer and if the mic is good and cord.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Old 01-29-2024, 07:42 AM
Just my 2 cents, but I would use any excuse to buy another brand of interface
Old 01-29-2024, 12:33 PM
Avid's MAudio experiment of chasing the low-end consumer market largely produced junk audio interfaces and that era also produced some awful software as well. So like Dave I would unfortunately aiming this stuff at the trash can.
And nobody here can guess what popup messages etc. you saw, if you cannot tell us.
And this laptop is a Mac? What exact model/specs? Running what OS? And for that matter, what exact model/specs is the other Mac?
The saving grace with the interface you have is it is USB audio class compliant, so should just work and does not need additional drivers. You can test the interface works from the Mac, just set it as the audio output and input using Audio MIDI Setup.app and Play with it in different apps. If it works there it should work in your DAWs.
You probably should have one interface dedicated to each DAW and even better only one DAW running at a time. I would be a little suspect about how well multi-client audio works with these boxes (but by all means test that, maybe you already have).
You likely should upgrade, there are no-end of great audio interfaces available from Focusrite, Presonus, Motu, RME, UAD, etc. there is no need to have an interface from Avid with modern Pro Tools. If these interfaces require drivers make sure they support the macOS versions your Mac can run. And ideally you can upgrade the macOS and run free Pro Tools Intro... that is likely better than ancient Pro Tools Express.
Fast Track Solo - Anyone still have one? arlettexmusic FireWire & USB Audio Interfaces (Mac) 6 03-14-2024 01:10 PM
Fast Track Solo + iPad Alex TCH FireWire & USB Audio Interfaces (Mac) 10 01-25-2015 07:22 PM
Fast Track Solo/Duo And PT 11 GTBannah FireWire & USB Audio Interfaces (Mac) 10 01-16-2015 08:26 PM
Fast Track Solo RRIVERA2012 Pro Tools Express on Windows 3 06-24-2014 07:26 AM
UA pre amp with fast track solo SidBarone Third Party Interfaces 2 04-22-2014 11:29 PM
