Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 11-12-2023, 06:27 PM
Dale-c Dale-c is offline
Default Mbox 3 pro on Mac mini 2018 not working
I have an mbox 3 Pro which works perfectly on my retina MacBook pro with a Thunderbolt 2 to Firewire adaptor.
However I can’t get it to work on my mac mini 2018 using a thunderbolt 3 to tb2 to firewire adaptor. My Motu firewire interface works fine with the same setup.
It shows up in the system profiler no issue. And I use an external drive loaded with Mojave because that is the latest OS supported. I can boot the laptop from the same drive and it works.
Old 11-12-2023, 07:15 PM
Default Re: Mbox 3 pro on Mac mini 2018 not working
Are you using the same MBox 3 Pro external power supply in all cases?
Old 11-13-2023, 06:22 AM
Yes. I have been trying to figure out what the difference is. The system recognizes it on the mac mini but the drivers aren’t connnecting for some reason.
The additional adaptor is different but the fact that system profiler indicated a connection to the system, and the fact that my Motu unit works fine, I don’t think that is it. Seems to be some sort of software issue
Old 11-13-2023, 06:11 PM
I'd try reinstalling the MBox 3 Pro driver when the Mac Mini is booted from the external hard drive and make sure you grant the needed privacy and security approvals for the driver.
I have no idea where Apple stashes the driver approval data on different systems, it might be in the computer's security enclave so you would lose that when moving the boot drive between systems. Even if that's not the issue a careful drive install might help anyhow.
Old 11-15-2023, 06:41 PM
I found another thread where someone had it working on a 2017 iMac which also required both adaptors. And then this person said he upgraded his ram from 8 to 32 and it stopped working. Well. I also upgraded my RAM from 8 to 32. So I put the 8 back in but no luck. Amazingly booted into ventura and it sees it in sound prefs and audio/midi setup but no sound. Butbin Mojave, a supported Os, nothing.
Not a huge deal. It works with the laptop I intend to use it with.
Old 11-15-2023, 06:51 PM
Did you actually try what I suggested?
Old 11-15-2023, 08:56 PM
Yes. I had already tried that multiple times.
Old 11-15-2023, 08:57 PM
I am going to install Mojave on the internal to see if it will run that way
Old 11-15-2023, 09:05 PM
Do you see a security/permissions warning when you install the driver and do you approve that in the preferences? (has to be within 30 minutes of doing the install).
Old 11-16-2023, 09:57 AM
No I didn’t. But I bet you are on the right track. I found this old thread here:
https://duc.avid.com/showthread.php?t=396087
MBox Studio - Mac Mini late 2018 Processor Issue macfac2020 MBOX Studio 10 01-05-2023 04:24 PM
MBox Mini not working! gagawhore 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-07-2012 10:15 PM
Mbox mini 3rd gen Not Working bouncingdj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-04-2012 12:20 PM
Mbox 2 mini not working with 10.6.3 domin9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-11-2010 11:53 PM
Mbox 2 and New Mac Mini - Not working.. PT8.... lexaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-01-2009 10:31 AM
