Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 01-11-2023, 05:58 PM
banjo71 banjo71 is offline
Default what's the worst that can happen
I know Avid recommends 7200 rpm for external drives. I bought the LaCie USB at 5400 rpm for some simple recording on my laptop. Two simultaneous tracks is all I'm recording. Then when I'm done recording, I'll transfer everything to my Glyph at 7200 rpm, where I add other instruments and finally mix. What's the probability I won't have any problems? I'm pretty sure I'll be ok, but was just checking.
Pro Tools 12.6.1 for Windows 10
ASUS Core i7 3770
Yamaha Steinberg UR 44
Golden Age Project Pre-73 JR
Warm Audio WA12 MKII Preamp
Glyph 1TB GPT50 external drive - Firewire
LaCie 1TB external drive - USB
JBL LSR305 monitors
AT 2020 & 2021
Equation F.20 condenser mic
Old 01-11-2023, 06:14 PM
BScout BScout is offline
Default Re: what's the worst that can happen
2 tracks but at what sample rate? Sample rate is going to be a big factor of how fast the drive needs to write.
Most likely you'll be fine.
But important, before going into any critical recording, is to test. Put the 2 tracks into record and see what happens (even with dead air/no mic connected.) The data amount will be the same. When we go into big record sessions (64 channels, etc.) we'll test the system by having it record for hours and see if it glitches or drops out of record.
(Also, if you are planning to punch-in/drop into record, realize the drive and USB connection also has to handle that which could be the playback of the previous recording. So it can be more than the demands of 2 recording tracks. In that case, it would be 2 playback PLUS 2 recording)
Old 01-11-2023, 06:16 PM
EGS's Avatar
EGS EGS is offline
just use disk cache - it's in the PT manual
Click for audio/video demo
Click for resume
Old 01-11-2023, 06:17 PM
Thanks for bringing the sample rate up. I was planning on 96 but I could do 48 too. I'll test it out when I get it. Thanks
ASUS Core i7 3770
JBL LSR305 monitors
AT 2020 & 2021
Old 01-11-2023, 06:26 PM
I'll probably test at 48 kHz and buffer size 512. I'm assuming I won't have any problems. I won't be punching in, either.
ASUS Core i7 3770
JBL LSR305 monitors
AT 2020 & 2021
Old 01-11-2023, 06:48 PM
JFreak's Avatar
JFreak JFreak is offline
I have that very same enclosure. It is good all-around box, but nothing to brag about.
Just a year ago I replaced the drive with SSD, and while the throughput didn't improve (SATA restriction) the latency went down to "nothing".
Janne
Worst weekend ever!!!!!!!!!! Raoul23 Windows 0 06-26-2011 02:15 PM
PT 7.1 Worst version ever the_dr38 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 46 04-13-2006 10:57 AM
Mac OS X worst than 9.2????? fradenigris 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 03-28-2005 09:47 PM
it was the worst I have ever seen surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-02-2001 07:50 AM
