Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 09-29-2021, 04:10 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Digi 002 error inputs
Oh alright, got it.
Sure, it sounds like a clocking issue. But in my thinking it sounds more like a software issue than hardware issue, because you can record few minutes clean.
To my knowledge oox drivers are qualified up to Sierra so even something as simple as OS upgrade may (or may not) solve your problem.
Driver downloads here. Bear in mind that when this page says untested it does not mean not working, only what it says, not tested. 002 and 003 are however effectively identical hardware, only different looking knobs.
Janne
Old 09-29-2021, 04:19 AM
jimijo jimijo is offline
Thanks!!
Right now I have the latest 11.1.5 drivers
It remains for me to test it on a computer with El Capitan. Let's see if that.....
Old 09-29-2021, 04:21 AM
JFreak's Avatar
As I already told you, that is notoriously the worst possible OS to have so plan an upgrade and report back. I have a hunch it fixes your issue.
Janne
Old 09-29-2021, 04:49 AM
Sorry but I do not understand well what is your solution, change the cable?
Old 09-29-2021, 04:51 AM
JFreak's Avatar
You can try that. Clocking problems most often are solved by changing a cable. Next best thing would be update your OS from the El Crapitan to something better.
Janne
  #16
Old 09-29-2021, 04:57 AM
Ok thanks a lot for the help!! I will change the cable first and if it is not solved I will update the Osx.
When I have it fixed I'll put it here in case it works for someone.
Greetings and thank you.
  #17
Old 09-30-2021, 08:54 AM
Hello good!! I have already received a new Firewire cable and ............ it works perfectly, there are no longer problems with the inputs, the problem was with the cable.
Thank you very much for the help JFreak!!
  #18
Old 09-30-2021, 09:20 AM
JFreak's Avatar
No problem, glad it worked out so easily
Janne
  #19
Old 11-07-2022, 09:57 AM
Good morning!! It's been a long time since the post but I'm thinking of updating the MacBook Pro Os, do you know how far it can be updated?
  #20
Old 11-07-2022, 10:39 AM
You should be able to answer this yourself. A great resource is https://everymac.com as is Apple's own support pages.
You also need to make sure you have a compatible version of Pro Tools. https://avid.secure.force.com/pkb/ar...tibility-Chart
You also need to make sure there are interface drivers compatible with your OS. If you are still using a 002 you are about to drive off the cliff into the chasm of disappointment and if you wan to be on recent macOS versions you should look for a current interface.
Control 24 inputs or Digi 192 inputs?? Al Rayder ProControl, Control|24, Command|8 6 06-22-2018 05:04 PM
Digi 003 Inputs DarylBham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-21-2011 03:52 PM
having more inputs on DIGI 001 hyrobase75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-27-2006 06:31 PM
RCA inputs to digi 002. help? grasshopper47 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-04-2005 09:21 PM
Digi 002 Inputs 5-8 starlark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-28-2004 07:15 PM
