Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 08-11-2021, 07:47 PM
arlettexmusic arlettexmusic is offline
Default Fast Track Solo - Anyone still have one?
Hi everyone. I still use my Fast Track Solo as my audio interface but lost the tablet cable that came with it to connect to ipad, as I never used it on the go before but would like to try to now.
However, I can't seem to find any indication about what type of cable I should look for. On the box and in the user manual it only says "a device link cable or a tablet port for ipad" and online I've heard people call it a "30 pin to usb adapter." But a regular sized USB cable does not fit in the slot on the Fast Track so I'm not sure what to do.
Does ANYONE out there know what cable I should order?
Thanks!
Old 08-24-2021, 07:15 AM
Default Re: Fast Track Solo - Anyone still have one?
Looking at the solo shows both a standard USB port and a separate tablet port, which I don't recognize. The USB port might be able to be used with an adapter(often called a camera kit). Letting us know which tablet you have might also help get better advice. I suggest calling B&H and chatting with someone in their recording department as they may have the cable you need
Old 08-24-2021, 07:47 AM
its2loud its2loud is offline
That was a Device Link cable. It only came in one iteration that would have a 30 pin connector on the other side to plug into much older iPads.
If you can find that cable anywhere, you might be able to find a 30 pin to lighting adapter to use with newer iPads.
Or this might work
https://www.sweetwater.com/store/det...ble-1.2-meters
Old 05-01-2023, 08:00 AM
RBxxx RBxxx is offline
Thanks for the replies everyone(this isn’t my thread, but relevant to my issue). I must not be explaining this properly. The cable I need is not the USB cable port, it’s the port I have circled in the attached pic. This cable has an odd connector that goes into the Tablet port(pictured) and the other end is Apple 30-pin for iPad. I hope that makes more sense. My apologies for the confusion.
Last edited by RBxxx; 05-02-2023 at 04:48 AM. Reason: Responded to the wrong thread, but relevant to my issue.
Old 05-01-2023, 08:26 AM
See my post above.
Old 05-02-2023, 04:49 AM
Ahs anyone tried the cable suggested? I have one on order now.
Old 03-14-2024, 01:10 PM
dave freeman dave freeman is offline
RBxxx - curious if you ever found the “tablet” cable…
The jack on the Fast Track could be female lightning, it’s definitely not the aforementioned focusrite cable on the discontinued sweetwater page.
dave freeman
Fast Track Solo/Duo And PT 11 GTBannah FireWire & USB Audio Interfaces (Mac) 10 01-16-2015 08:26 PM
Fast track solo out of the box not working yoplin FireWire & USB Audio Interfaces (Mac) 0 10-10-2014 04:18 PM
Fast Track Solo RRIVERA2012 Pro Tools Express on Windows 3 06-24-2014 07:26 AM
UA pre amp with fast track solo SidBarone Third Party Interfaces 2 04-22-2014 11:29 PM
Fast Track Solo - no output Elnico50 FireWire & USB Audio Interfaces (Mac) 0 12-17-2013 05:01 PM
