Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 05-15-2020, 02:47 PM
Dale144 Dale144 is offline
Default New 2020 Macs. Mini or MBP??
First post, so hello, hope you're all doing well in these times and thanks for any help in advance.
Looking to get an upgrade on my Mac and wondering if you could give me some direction. I know this is talked about a lot but looking for specific on these 2 machines.
What is going to run pro tools better for mixing and recording. Using lots of plug ins and a few VI. 30 to 70 track sessions.
MacBook Pro 13-Inch "Core i5" 2.0 GHz 2020 $1799
Has newer 10 Gen chip and faster ram but overall slower GHz and less cores (4)
https://everymac.com/systems/apple/m...sor-specs.html
Vs.
Mac mini "Core i7" 3.2GHz 2020 $1499
Older chip and slower ram but more cores (6) and faster GHz
https://everymac.com/systems/apple/m...018-specs.html
Will upgrade on purchase the mini to 16Gb ram same as MPB. The Mini 2020 version is the same spec as linked but with larger SSD.
Geek bench put the mini faster but Ive read its about the number of threads? and the faster chip is better for that with pro tools.
Any thoughts would be greatly appreciated.🙏🏼
Old 05-15-2020, 02:54 PM
JFreak's Avatar
JFreak JFreak is online now
Default Re: New 2020 Macs. Mini or MBP??
Hi, welcome to the community.
By doing a simple search you would have already found that i7 or better CPU is highly recommended for PT
Janne
Old 05-15-2020, 03:34 PM
Yes, I did a search and read many post on the subject,
I also read it is about a balance of cores, number of threads per seconds (not sure if that is the right terminology?) which is always faster on newer chips and the speed of ram as well. I also read the newer i5 are always as fast as the old i7, hence my question.
The MBP's ram is faster and has a newer chip even though its i5. So I thought someone who knew more about it than me would give me a better answer than what I have already read about the topic.
Thanks
Old 05-15-2020, 03:38 PM
Carl Lie Carl Lie is offline
if you don't need the monitor than I'd go with the mini.
What are Mac you upgrading from?
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 05-15-2020, 03:52 PM
JFreak's Avatar
RAM is so relatively fast you should not get fixated to that. Always many times faster than anything that feeds it, also many times slower than the small amount of memory CPU has internally.
Janne
Old 05-15-2020, 03:55 PM
C
I have a 2017 13 inch MBP 3.1Ghz i5
Old 05-15-2020, 03:56 PM
I don't really need the monitor, its useful for travel but not much of that going on now and I really just want the best performance the rest I can make do.
Old 05-15-2020, 04:08 PM
JFreak's Avatar
Then mini is better bet. Just remember you cannot upgrade anything later so need to buy as much memory and storage as you think you will be needing.
Janne
Old 05-15-2020, 04:31 PM
Wolfgang Eller Wolfgang Eller is online now
Memory is changeable storage not.
Afaik.
www.srs-mastering.de
Mac Pro 6.1-8core, OS 12.6, PT2023, HDX2, Sonnet Echo Express III-R, Madi Interface.
Old 05-15-2020, 04:48 PM
Thanks for the replys, I was leaning towards the mini and seen it had the better Geekbench 5 scores but just wanted to make sure that the newer gen chip in the MBP wouldn't be better. Cheers
Pro Tools 2020.3
OS Mojave 10.14.6
13 inch MBP 2017 3.1 GHz Intel Core i5
Apogee Element
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
New Macs vs Mac mini vs MacBook Pro Markk Pro Tools HDX & HD Native Systems (Mac) 8 06-29-2013 10:58 AM
New Macs introduced! New Imac, Mac Mini, 13" Retina Macbook Pro nst7 Pro Tools 10 22 10-25-2012 10:49 AM
intel macs vs. slightly older macs Jperkins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-14-2007 09:36 AM
