With HDN do hardware inserts stay active when LLM is on?
I'm aware that plugins and sends are inactive when LLM is on with HDN, but what happens to hardware inserts?
Since HDN supports true hardware inserts the same way TDM and HDX do, do they stay active with LLM enabled with HD Native? Related, what happens to HEAT in HDN with LLM enabled? Thanks! |
Re: With HDN do hardware inserts stay active when LLM is on?
All sends and inserts are made inactive with LLM on any record-enabled track. Personally, having used PT for 10+ years and HD/Native for 2, I have never had a need for LLM, even when tracking 6 piece bands while providing 5 stereo headphone mixes from the sessions.
Thanks. I'm a little surprised that hardware inserts are bypassed.
I hear you. I tried HDN when PT11 came out and found it less than satisfactory latency-wise at 44 vs our HD4 systems. However, I'm now reconsidering a switch to HDN and 96kHz instead, for latency benefit. PT12 has really brought some nice options forward. HDN at 96 will be a similar latency to TDM at 44, as long as I stay at a buffer of 64. That's the biggest dilemma. If I have to increase the buffer it's much higher latency than TDM and gets difficult for some vocalists due to the comb filtering phenomenon. With the freeze and commit options now I should be able to work around it, though, for those times when I have to do a late project overdub. |
I would definitely move up from 44.1, but for me(and many here), 48K is fine. Audio for video usually is 48K anyway so that can save conversion(if it matters) 96K can really hammer the computer, but if yours is up to the task, then go for it. I've been tracking live bands on HDN at the 64 buffer while sending 5 stereo headphone mixes from the session and rarely hear a peep about latency(but I am careful to not use any plugins with latency while tracking). I have only recently added the facility to do hardware inserts and have yet to try tracking with any in place(so far, outboard gear has been patched to the incoming signal).
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
Yeah I bet, HDN can't compare or beat TDM for latency.... I usually track everything at 44.1 as Dave said...96k is a killa on CPU and makes me push my buffer up too high. (And it uses 2x of those sharks too!) 44.1 is good and I can ride it low (buffers) for just this if needed HDN it isn't TDM or HDX but it's better than FW
Hardware insert 1&2 cutting off other hardware inserts on aux tracks | Led | Windows | 4 | 12-09-2013 09:19 AM |
The new i/o setup is seeing my inactive hardware inserts as active | crizdee | Pro Tools TDM Systems (Mac) | 0 | 11-04-2010 05:47 AM |
How do I disable tons of "some of the inserts could not be made active" | Alécio Costa | Pro Tools TDM Systems (Mac) | 6 | 03-14-2010 12:03 PM |
Hardware Inserts | CosmicJunkie | Pro Tools TDM Systems (Mac) | 1 | 11-20-2007 03:12 AM |
Hardware Inserts | bradd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 12-10-2004 06:50 AM |
