Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 02-04-2015, 03:48 PM
vinap1 vinap1 is offline
Default Avid Fast Track solo white noise
Hi Everyone!
I've been having some issues with my "Avid Fast Track solo" being connected via USB to the Laptop.
After successfully installing the newest drivers and firmware, I discovered I cannot use the box at all. trying to play any audio on my Laptop, Fast track produces loud bursts of distorted white noise. it comes and goes every 1,5-2 seconds , in various loudness.
Hm, what could be the Problem?
I've used the whole bunch of other USB interfaces including newest AudioBox iTwo from Presonus on the same USB Ports , on the same machine, with no single issue.
I'm using Windows 7 64 bit.
Sounds like a driver/firmware problem of Avid Fast Track solo.
Please assist me in this.
Thank you!
Vitaly
Old 02-05-2015, 06:04 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Avid Fast Track solo white noise
Can you post your full system specs? Are you connecting the interface to a USB 3 (blue or marked SS) or USB 2 (black) port?
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 02-05-2015, 07:09 AM
It's USB 2 ( standard Laptop configuration, nothing fancy. Windows 7 64 bit, 4gigs of ram, dual core Athlon CPU, )
Old 11-07-2015, 05:31 PM
NikelButt NikelButt is offline
Hi there! I have a similar problem. Constant white noise during playback at unexpected times. Sometimes it is enough to stop-start playback to restore audio flow, but sometimes i need to restart PC. Think it may be tied with some sort of multi-task driver issues...
Old 02-16-2016, 07:10 AM
mremming mremming is offline
I am experiencing a similar problem with a new to me PC here is a copy of a email that I sent to Sweetwater:
More info for your tech. I changed computers last week here are the specs on the new one.
1 x HP Z400 Workstation Intel Xeon W3520 2.66GHz Quad Core CPU, 8GB memory, 120GB SSD HD + 1TB HD, NVIDIA ...
Colors: Black/Silver / Operating System: Windows 7 Professional / CPU Type: Xeon Quad Core / CPU Speed: 2.66 GHz / GPU/VGA Type: NVIDIA Quadro FX580 / Memory Capacity: 8 GB DDR3 / SSD: 120 GB / HDD: 1 TB
Loaded the current driver for the Fast Track off of Avid's site, everything connects find. Using PT 10, added a wave file backup track for a solo song I have been working on and playback of the wav file is random white noise, very shocking when you have the volume up on the monitors. So I thought I might have a bad file and import a known good wave file and I have the same problem. I then attempted to make a voice recording and have all types of white noise and occasionally sound like it should be but jumping back and forth with the white noise. I havne't used the Fast track for several months not really sure what is going on.
Old 10-05-2017, 03:43 PM
adamino adamino is offline
I'm having the same issues here.I get loud bursts on my Acer Workstation.
When I connect the Avid Fast Track solo to my Fujitsu Workstation I dont get these white bursts.
Old 08-22-2019, 09:45 PM
Found solution!
The problem was in the processor operating modes (EIST , turbo boost, C1 / C6 modes).
You need to disable them in BIOS.
Old 04-26-2020, 03:44 PM
DinoVert DinoVert is offline
I’m having a similar problem after getting a new interface, I can’t seem to get the white noise out of playback, I’ve tried changing buffer sizes and sample rates and nothing helps.
External Noise when recording with Fast Track Solo and Garageband on IPad 6.1.3 The Librarian Getting Started 0 03-20-2014 12:36 AM
sell Pro Tools 11 + Avid Fast Track solo (ilok 2 included!) kind Buy & Sell 0 02-20-2014 01:48 PM
Avid Fast Track Solo Lombardi FireWire & USB Audio Interfaces (Mac) 1 09-09-2013 03:10 PM
Avid Fast Track Solo and Duo Announced Bruce Paine FireWire & USB Audio Interfaces (Mac) 0 04-13-2013 11:54 AM
Avid Fast Track Solo and Duo Announced Bruce Paine FireWire & USB Audio Interfaces (Win) 0 04-13-2013 11:54 AM
