Old 01-03-2014, 02:34 AM
Default Re: Is the Clip Gain the same as a Trim Plugin?
Clip-gain is sample-accurate unlike plugin-automation. CG is much better and more precise for extra short gain treatment (de-easing, de-clicking etc.)
Old 01-03-2014, 03:03 AM
JFreak's Avatar
JFreak JFreak is offline
PT11 automation is time-stamped and sample-accurate
Janne
Old 09-15-2022, 07:54 AM
Saucy CT Saucy CT is offline
Reading through this old thread and saw this comment. Pre-HEAT does seem like the most important thing. So that begs the question: is a Trim plugin in the first slot Post-HEAT?
Otherwise, seeing as how they are nearly identical (assuming Trim plug is in first slot) in terms of being level control pre-fader, I prefer to use first-slot Trim plugins as I find they are more flexible in terms of my workflow—easier to adjust quickly and copy to other tracks.
I am hoping you are still a mod. Thanks if you see and answer this.
Old 09-15-2022, 03:31 PM
I think you are asking the wrong question What is the purpose of using the Trim plugin(for you)? For me, I use the Trim plugin in the last slot(of AUDIO and INSTRUMENT tracks, only) for the purpose of bringing the entire mix level down, but without altering the overall balance. My purpose is to counter my habit of mixing too hot(and it works perfectly for this). Let us know what you are wishing to do as there may be other ideas you haven't considered
Old 09-15-2022, 05:07 PM
smurfyou smurfyou is offline
HEAT can be pre or post insert, per track.
I haven't touched the Trim plugin since clip gain was introduced.
~Will
AudioSuite Gain/Normalize also on Clip Gain A-n-d-i macOS 0 03-13-2014 12:46 PM
Gain plugin bug? Writes distortion to start of first processed clip iain_m Pro Tools 10 18 06-03-2013 03:41 PM
Clip gain on clip groups: bug or feature? idris Post - Surround - Video 6 01-02-2013 10:48 PM
Clip Gain doesn't follow trim edits bug? JR Fountain Post - Surround - Video 0 02-17-2012 06:28 AM
Is it better to use a Trim plugin or Gain plugin? SpinningDisk Tips & Tricks 5 01-19-2010 02:43 PM
