Old 11-03-2011, 06:27 AM
saxygreeneyes saxygreeneyes is offline
Default No input from 003 rack to Pro Tools 9
I just installed Pro Tools 9 on my Macbook Pro and am trying to get set up to record. I have the Digidesign 003 rack and just updated the drivers and firmware on that last night. Everything seems to be connected ok but I'm not getting an input of any kind. I did a test with the click track and can hear that as an output.
I plugged a Shure SM58 mic into the input 1 XLR on the back of the rack. Turned up the volume for input 1 on the front and get nothing. I don't see any reading in Pro Tools either. Any help would be greatly appreciated!
Thanks!
Old 11-03-2011, 07:37 AM
Vovique Vovique is offline
Default Re: No input from 003 rack to Pro Tools 9
Make sure that:
1. 003 is set as your playback engine (Setup>Playback Engine)
2. 003 Inputs and outputs are setup the right way (Setup>I/O, press "Default" to list 003 inputs correctly)
3. You have created a mono audio track with "Analog 1" input selected, and record enabled this track (red record button flashes).
Old 11-03-2011, 08:43 AM
Question Re: No input from 003 rack to Pro Tools 9
Ok great will check those things! I believe they were that way last night when I was looking at the setup. But I'll check again. Are there 2 ways to power up the Digidesign 003 rack? I know there is a power button right on the front. I'm just wondering if maybe I need to fully power it up using another switch so that I can use the phantom power for mics etc.
003 rack input I/0 not available thorbax Pro Tools 10 4 11-22-2013 05:23 PM
Mic 3-4 Input Issues 003 Rack dlipsjr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-12-2011 05:18 PM
003 Rack DI Input TS - TRS okay? getz76 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-24-2008 01:14 PM
Jack Input on Rack 003 as a DI Matt Darcy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-20-2008 05:47 AM
I/O LINE INPUT, I/O OPTICAL INPUT DIGI 002 RACK JOAN ROSALES 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-28-2003 04:08 PM
