Old 05-12-2010, 03:42 PM
tobbenos tobbenos is offline
Default Crashes while launching the last plug-in
I've just swapped my two-year old MacBook Pro into a new one (i5 with OS X 10.6.3), and restored a Time Machine backup.
At first, I had some problems with audio not coming through from iTunes and through my Mbox 2, so I reinstalled PTLE (8.0.3).
However, on every launch, the splash screen hangs when launching the last plug-in. Firstly, it always hung on Xpand!, and thinking it was the problem, I removed it from the plug-in folder. But then PTLE only hung on the plug-in that was now the last in the folder. This proved to be the same as I removed more and more plug-ins. Any ideas on this?
Also, I am experiencing a lot of crashes and hangs on different programmes (Safari, iTunes, Mail etc.) with the Mbox 2 plugged in. When I start up the computer without the Mbox 2, everything runs smoothly (as it should).
Here is part of a crash report after PT hung on the last plug-in:
Date/Time: 2010-05-13 00:30:49 +0200
OS Version: 10.6.3 (Build 10D2094)
Architecture: x86_64
Report Version: 6
Command: Pro Tools LE
Path: /Applications/Digidesign/Pro Tools/Pro Tools LE.app/Contents/MacOS/Pro Tools LE
Version: 8.0.3 (8.0.3f249)
Parent: launchd [128]
PID: 341
Event: hang
Duration: 6.02s (sampling started after 2 seconds)
Steps: 42 (100ms sampling interval)
Pageins: 0
Pageouts: 0
Process: Pro Tools LE [341]
UID: 501
Process: AirPort Base Station Agent [161]
Path: /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
UID: 501
Thread 11a6db7c DispatchQueue 1
User stack:
42 ??? (in AirPort Base Station Agent + 5692) [0x10000163c]
42 NSApplicationMain + 364 (in AppKit) [0x7fff85c81d8c]
42 -[NSApplication run] + 395 (in AppKit) [0x7fff85c8906f]
42 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155 (in AppKit) [0x7fff85cc3399]
42 _DPSNextEvent + 708 (in AppKit) [0x7fff85cc3a4a]
42 BlockUntilNextEventMatchingListInMode + 59 (in HIToolbox) [0x7fff88662798]
42 ReceiveNextEventCommon + 310 (in HIToolbox) [0x7fff886628df]
42 RunCurrentEventLoopInMode + 333 (in HIToolbox) [0x7fff88662ada]
42 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x7fff833e38df]
42 __CFRunLoopRun + 1698 (in CoreFoundation) [0x7fff833e4452]
42 mach_msg_trap + 10 (in libSystem.B.dylib) [0x7fff83a8f75a]
Kernel stack:
42 ipc_mqueue_receive_continue + 0 [0x210c23]
Thread 11ab93d4 DispatchQueue 2
User stack:
42 start_wqthread + 13 (in libSystem.B.dylib) [0x7fff83aa9385]
42 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x7fff83aa94e8]
42 _dispatch_worker_thread2 + 252 (in libSystem.B.dylib) [0x7fff83aa9bbe]
42 _dispatch_queue_invoke + 185 (in libSystem.B.dylib) [0x7fff83aaa094]
42 kevent + 10 (in libSystem.B.dylib) [0x7fff83aa84ea]
Kernel stack:
42 kevent + 97 [0x4706f6]
Thread 11bca3d4
User stack:
42 thread_start + 13 (in libSystem.B.dylib) [0x7fff83ac8769]
42 _pthread_start + 331 (in libSystem.B.dylib) [0x7fff83ac88b6]
42 select$DARWIN_EXTSN + 10 (in libSystem.B.dylib) [0x7fff83ad3286]
Kernel stack:
42 sleep + 52 [0x487017]
Binary Images:
0x100000000 - 0x100027fff com.apple.AirPortBaseStationAgent 1.5.5 (155.2) <00010203-0405-0607-0809-0A0B0C0D0E0F> /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
0x7fff83398000 - 0x7fff8350dfef com.apple.CoreFoundation 6.6.1 (550.19) <D119AB06-B148-8FE2-3137-7BF50A29F084> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff83a8e000 - 0x7fff83c4dff7 libSystem.B.dylib ??? (???) <D8F3BC70-08DE-8D03-2930-2ACC3F05F5ED> /usr/lib/libSystem.B.dylib
0x7fff85c80000 - 0x7fff86675fe7 com.apple.AppKit 6.6.5 (1038.29) <8938E4FE-E661-ABC6-097F-00E258F8345B> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff88634000 - 0x7fff88932fef com.apple.HIToolbox 1.6.2 (???) <3A6CD66E-A65D-9DC2-0FEF-32D31CBEF3DD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
Process: AppleVNCServer [156]
Path: /System/Library/CoreServices/RemoteManagement/AppleVNCServer.bundle/Contents/MacOS/AppleVNCServer
UID: 501
Thread 11a58000 DispatchQueue 1
User stack:
42 ??? (in AppleVNCServer + 5220) [0x100001464]
42 ??? (in AppleVNCServer + 6677) [0x100001a15]
42 ??? (in AppleVNCServer + 19068) [0x100004a7c]
42 CFRunLoopRun + 70 (in CoreFoundation) [0x7fff833e3666]
Kernel stack:
Thread 11a9db7c DispatchQueue 2
User stack:
Kernel stack:
Thread 11ab9000
User stack:
42 PrivateMPEntryPoint + 63 (in CarbonCore) [0x7fff811cb045]
Kernel stack:
Process: configd [14]
Path: /usr/libexec/configd
UID: 0
Thread 8a87b7c DispatchQueue 1
User stack:
42 start + 52 (in configd) [0x100000cf0]
42 main + 2051 (in configd) [0x100001506]
42 server_loop + 72 (in configd) [0x100001d5c]
Kernel stack:
Thread 95b7000
Kernel stack:
42 IOWorkLoop::threadMain() + 0 [0x547d54]
Thread 95b73d4
Kernel stack:
Thread 95b77a8
Kernel stack:
41 thread_call_initialize + 663 [0x22fa8f]
1 call_continuation + 28 [0x29e6cc]
1 thread_call_initialize + 1073 [0x22fc29]
1 thread_block_parameter + 32 [0x227155]
1 thread_block_reason + 309 [0x2270d4]
1 thread_go + 1982 [0x2264b0]
1 thread_setrun + 1351 [0x2256c6]
1 machine_idle + 252 [0x2a9afb]
Thread 98adb7c
Kernel stack:
37 IOWorkLoop::threadMain() + 0 [0x547d54]
5 call_continuation + 28 [0x29e6cc]
4 IOWorkLoop::threadMain() + 26 [0x547d6e]
4 IOWorkLoop::runEventSources() + 90 [0x547914]
4 IOInterruptEventSource::checkForWork() + 183 [0x5488e3]
4 com.apple.NVDAResman 6.1.4 + 441982 [0x9d7e7e]
4 com.apple.NVDAResman 6.1.4 + 1639082 [0xafc2aa]
3 com.apple.nvidia.nv50hal 6.1.4 + 1279679 [0x166d6bf]
3 com.apple.nvidia.nv50hal 6.1.4 + 1415664 [0x168e9f0]
3 com.apple.NVDAResman 6.1.4 + 1928171 [0xb42beb]
3 com.apple.nvidia.nv50hal 6.1.4 + 1418557 [0x168f53d]
3 com.apple.nvidia.nv50hal 6.1.4 + 1272307 [0x166b9f3]
2 com.apple.NVDAResman 6.1.4 + 1651755 [0xaff42b]
2 com.apple.nvidia.nv50hal 6.1.4 + 1255153 [0x16676f1]
2 com.apple.NVDAResman 6.1.4 + 1651705 [0xaff3f9]
1 com.apple.nvidia.nv50hal 6.1.4 + 1260426 [0x1668b8a]
1 com.apple.nvidia.nv50hal 6.1.4 + 1502337 [0x16a3c81]
1 com.apple.nvidia.nv50hal 6.1.4 + 1499767 [0x16a3277]
1 com.apple.nvidia.nv50hal 6.1.4 + 1499415 [0x16a3117]
1 com.apple.nvidia.nv50hal 6.1.4 + 1496395 [0x16a254b]
1 com.apple.NVDAResman 6.1.4 + 1517955 [0xade983]
1 com.apple.NVDAResman 6.1.4 + 404383 [0x9ceb9f]
1 com.apple.nvidia.nv50hal 6.1.4 + 1260635 [0x1668c5b]
1 com.apple.NVDAResman 6.1.4 + 1521725 [0xadf83d]
1 com.apple.nvidia.nv50hal 6.1.4 + 1090401 [0x163f361]
1 com.apple.nvidia.nv50hal 6.1.4 + 1187682 [0x1656f62]
1 com.apple.nvidia.nv50hal 6.1.4 + 1174329 [0x1653b39]
1 com.apple.nvidia.nv50hal 6.1.4 + 1163753 [0x16511e9]
1 com.apple.nvidia.nv50hal 6.1.4 + 1154742 [0x164eeb6]
1 com.apple.NVDAResman 6.1.4 + 1512509 [0xadd43d]
1 com.apple.NVDAResman 6.1.4 + 1504910 [0xadb68e]
1 com.apple.NVDAResman 6.1.4 + 135556 [0x98d184]
1 com.apple.NVDAResman 6.1.4 + 1651606 [0xaff396]
1 com.apple.nvidia.nv50hal 6.1.4 + 1268039 [0x166a947]
1 com.apple.NVDAResman 6.1.4 + 1651630 [0xaff3ae]
1 com.apple.nvidia.nv50hal 6.1.4 + 1257290 [0x1667f4a]
1 com.apple.nvidia.nv50hal 6.1.4 + 1253985 [0x1667261]
1 com.apple.nvidia.nv50hal 6.1.4 + 234648 [0x156e498]
1 com.apple.nvidia.nv50hal 6.1.4 + 267301 [0x1576425]
1 com.apple.nvidia.nv50hal 6.1.4 + 1280359 [0x166d967]
1 com.apple.nvidia.nv50hal 6.1.4 + 979929 [0x16243d9]
1 com.apple.NVDAResman 6.1.4 + 1517476 [0xade7a4]
1 com.apple.NVDAResman 6.1.4 + 1492025 [0xad8439]
1 com.apple.NVDAResman 6.1.4 + 1489235 [0xad7953]
1 IOWorkLoop::threadMain() + 188 [0x547e10]
Thread 98b4b7c
Kernel stack:
42 aio_return + 295 [0x46392f]
Thread 98c2000
Kernel stack:
Thread 9963000
Kernel stack:
Thread 99633d4
Kernel stack:
40 thread_call_initialize + 663 [0x22fa8f]
2 call_continuation + 28 [0x29e6cc]
1 thread_call_initialize + 896 [0x22fb78]
1 com.apple.iokit.IOUSBHIDDriver 3.9.6 + 17529 [0x119e479]
1 com.apple.iokit.IOUSBHIDDriver 3.9.6 + 10562 [0x119c942]
Thread b792000
Kernel stack:
Thread b8cc000
Kernel stack:
Thread 117ef7a8
Kernel stack:
Thread 11802b7c
Kernel stack:
Thread 1185d3d4
Kernel stack:
Thread 11a58b7c
Kernel stack:
Thread 11a9d000
Kernel stack:
Thread 11ab9b7c
Kernel stack:
Thread 11aeb3d4
Kernel stack:
Thread 11b53b7c
Kernel stack:
Thread 11b8f3d4
Kernel stack:
Thread 11d15000
Kernel stack:
Thread 11d98000
Kernel stack:
Thread 11d983d4
Kernel stack:
Thread 121da3d4
Kernel stack:
Thread 121da7a8
Kernel stack:
Thread 121dab7c
Kernel stack:
Thread 122753d4
Kernel stack:
Thread 122757a8
Kernel stack:
Thread 12275b7c
Kernel stack:
Thread 122913d4
Kernel stack:
42 call_continuation + 28 [0x29e6cc]
42 com.digidesign.mbox2.driver 8.0.3f1 + 18830 [0x198d98e]
42 IOCommandGate::runAction(int (*)(OSObject*, void*, void*, void*, void*), void*, void*, void*, void*) + 271 [0x548d8f]
42 com.digidesign.mbox2.driver 8.0.3f1 + 33017 [0x19910f9]
42 com.digidesign.mbox2.driver 8.0.3f1 + 28991 [0x199013f]
42 com.digidesign.mbox2.driver 8.0.3f1 + 34204 [0x199159c]
42 com.apple.iokit.IOAudioFamily 1.7.6fc2 + 22497 [0x101e7e1]
42 com.digidesign.mbox2.driver 8.0.3f1 + 52629 [0x1995d95]
42 com.digidesign.mbox2.driver 8.0.3f1 + 38285 [0x199258d]
42 com.digidesign.mbox2.driver 8.0.3f1 + 4432 [0x198a150]
42 IOSyncer::wait(bool) + 81 [0x52c047]
42 thread_block + 33 [0x227178]
42 thread_block_reason + 331 [0x2270ea]
42 thread_dispatch + 1966 [0x226e4b]
42 machine_switch_context + 753 [0x2a6a37]
Thread 12e943d4
Kernel stack:
2 thread_call_initialize + 896 [0x22fb78]
2 com.apple.iokit.IOUSBHIDDriver 3.9.6 + 17529 [0x119e479]
2 com.apple.iokit.IOUSBHIDDriver 3.9.6 + 10845 [0x119ca5d]
2 IOCommandGate::runAction(int (*)(OSObject*, void*, void*, void*, void*), void*, void*, void*, void*) + 96 [0x548ce0]
2 com.apple.iokit.IOUSBFamily 3.9.7 + 89525 [0x117edb5]
2 IORecursiveLockLock + 42 [0x52b7b5]
2 lck_mtx_lock + 504 [0x298228]
2 lck_mtx_lock_wait_x86 + 330 [0x29d846]
Model: MacBookPro6,2, BootROM MBP61.0057.B07, 2 processors, Intel Core i5, 2.53 GHz, 4 GB, SMC 1.58f16
Graphics: NVIDIA GeForce GT 330M, NVIDIA GeForce GT 330M, PCIe, 256 MB
Graphics: Intel HD Graphics, Intel HD Graphics, Built-In, 288 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.10.131.14.7)
Bluetooth: Version 2.3.2f5, 2 service, 2 devices, 1 incoming serial ports
Network Service: Innebygd Ethernet, Ethernet, en0
Serial ATA Device: ST9500420ASG, 465,76 GB
Serial ATA Device: MAT[bleep][bleep][bleep][bleep]ADVD-R UJ-898
USB Device: Hub, 0x0424 (SMSC), 0x2514, 0xfd100000
USB Device: Mbox 2, 0x0dba, 0x3000, 0xfd130000
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0xfd120000
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8507, 0xfd110000
USB Device: Hub, 0x0424 (SMSC), 0x2514, 0xfa100000
USB Device: USB2.0 Hub, 0x05e3 (Genesys Logic, Inc.), 0x0608, 0xfa140000
USB Device: USB2.0 Hub, 0x05e3 (Genesys Logic, Inc.), 0x0608, 0xfa144000
USB Device: iLok, 0x088e, 0x5036, 0xfa144200
USB Device: DeskJet 840C, 0x03f0 (Hewlett Packard), 0x0604, 0xfa142000
USB Device: External HDD, 0x1058 (Western Digital Technologies, Inc.), 0x0910, 0xfa141000
USB Device: BRCM2070 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8218, 0xfa113000
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0237, 0xfa120000
USB Device: Internal Memory Card Reader, 0x05ac (Apple Inc.), 0x8403, 0xfa130000
FireWire Device: 1394 Storage Front Panel*, Maxtor, Up to 800 Mb/sec
Old 05-13-2010, 01:59 AM
Default Re: Crashes while launching the last plug-in
SOLVED
As proposed in another thread, I put the Mbox 2 in the USB port closest to the SD slot. Having the older MacBook Pro, you were supposed to have it plugged in the USB port closest to the power cable, now it seems to be the opposite. Everything seems to work very nicely by now..!
Old 05-28-2010, 04:11 PM
galliv galliv is offline
I got the same problem... IT'S VERY FRUSTRATING. I try to check if you solution is good for me... Let you know...
Old 06-01-2010, 01:20 AM
It seems working for me as well....
6.4 crashes when launching on new pc Minimalism 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-13-2009 02:51 PM
Argh Help! PT 8.03c not launching, crashes every time Worship Factory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-15-2009 03:29 PM
7.4.2 crashes when launching whylago 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-28-2008 04:00 PM
pro tools crashes when launching 'digirewire' stefunktrumpet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-03-2008 01:41 PM
New computer crashes when launching PTLE MixMastaShizNasta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-14-2005 10:21 PM
