Old 02-26-2002, 10:51 AM
ODC ODC is offline
Default Matching MixBus level with track channel during calibration.
Hi everyone et bonsoir de Paris !
I've been experiencing some strange readings when recalibrating my rig last night.
I use an old Adat bridge (16bit) as my master output then go to a small mixer for listening.
I have a pair of Dorrough meters (40-C2) and a DK MSD600 for monitoring levels.
What I did first was pluging one of the Adat bridge's outputs directly into one Dorrough meter.
The Adat bridge is calibrated to +4dBu using internal PT option.
I've inserted Generator X plug for generating the Test tone on the master bus.
I fed the meter with a -18dBFS, 1000Hz sine wave and adjust the trim pot to 0dB AVG.
Then, by curiosity, I did the same technique, inserting the test tone in a track channel.
Problem is the levels didn't match !
I've called Digi france today and the guy told me they are aware of this problem !!!
Could someone explain this to me ? Dave, Nika ?
Et merci d'avance !
003 Calibration Level drummer9 Pro Tools 9 0 06-30-2011 05:38 AM
CALIBRATION LEVEL Sput 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-20-2006 07:36 AM
Level calibration DonaldR Tips & Tricks 1 11-02-2004 08:31 AM
Level matching problem andre tchmil Pro Tools TDM Systems (Mac) 0 04-19-2001 12:39 AM
level calibration coaster Tips & Tricks 0 11-27-1999 08:57 AM
