Australian Broadcast Specs \"Crackdown\"
Hi all, i have just received an email i thought could be worth sharing. (sorry if it is a bit OT...)
The following is an email received from a Channel 7 (more accurately, Prime TV, Canberra) Media Co-Ordinator regarding OP-29. As anyone who mixes for Australian TV knows, OP-29 requests 12 Frames of silence at the head and tail of any TVC. From my understanding, this is a bit of a redundant rule that was originally formed before TVC's were digitally logged (?). As a result, the 12 frame rule has been a bit relaxed and pretty much everyone i know starts their mixes from around 5-6 frames in and out... The email is as follows... Good Morning, Could the following excerpt from Free TV's Operation Practise OP29 document please be urgently distributed to all media producers, agencies, production houses and creative houses that you are in contact with. It has been sourced from the following link, which is downloadable if required: http://intranet1/primeweb/code_of_pr...ber%202004.pdf 10. COMMERCIAL TIMING 10.1 The duration of commercial or promotional material should be measured from the start of active video to the end of active video. 10.2 Sound should commence 0.5 seconds after the commencement of active video. This provides time for the sound channel to be opened after the start of video without risk of sound clipping and provides aural separation between adjacent commercials and program material. 10.3 The end of the commercial sound including any sound tag shall occur 0.5 seconds before the end of active video. 10.4 Accurate identification of first frame of active video on commercials should be provided. This shall be by the inclusion of a white marker on the color black in the 2 second interval following the visual count down signal, top right of picture, outside picture safe on the frame immediately before first frame of active video. The white marker should be a minimum picture height for SD of 12 lines and minimum width of 18 pixels. For HD, the white marker should be a minimum picture height of 24 lines and a minimum width of 36 pixels. Timing of the commercial is referenced from the first frame of active video. What I would like to refer to particularly is items 10.1, 10.2 and 10.3. Many commercials have been arriving on station with audio beginning on the first active video frame. Commercials that have audio that begins on frame 11 or less of the active video should not be broadcast as per reason stated in item 10.2 of the above. So simply put, there should be 12 frames of silence at the beginning of the commercial and then 12 frames of silence at the end of the commercial. For reference 0.5 seconds equals 12.5 frames (video broadcasts at 25 frames per second). Unfortunately this has also been missed by our own ingest teams until recent times. Therefore we must bring things back into equilibrium: Any commercial that we receive from now onward with audio that begins on frame 6 or less of the active video will instantly be rejected and will need to be resent as a revised commercial. Commercials with audio that begins on frame 7 or more (up until and including frame 11) will be dubbed in and allowed to air momentarily, on the prevision that a revision is sent within a couple of days. Sales Teams will be required to organise this. Then as of Monday 4th of February, any commercial that requires ingesting that has audio beginning frame 11 or less of the active video, will be refused entirely. Please note that getting a CAD number does not cover this - this operational practise is the sole responsibility of the commercial producer. Please also take note, this will be enforced regardless of what other stations are doing. I thank you for your cooperation and understanding in this matter. Best Regards Daniel Sanguineti (Embedded image moved to file: pic04667.jpg) Media Co-ordinator Traffic Department, Canberra int: 46 27 51 direct: (02) 62 423 751 mobile: (04) 09 072 549 [email protected] So anyone who's spots may be heading to Prime TV, Canberra, and who doesn't leave the exact 12 frames, will potentially have their spots rejected.
Matt Perrott Sound Designer and Engineer Sydney, Australia |
Re: Australian Broadcast Specs \"Crackdown\"
Yikes! I can't imagine any of my ad clients giving up that second of real estate. It is hard enough to squeeze 45sec of copy into a 30sec spot, forget about 29!
Colin Van Hattem Noizemaker Productions |
many thanks.., important news for us ozzys
M:)
bless the fate that brings good friends together. I Mac 24 inch screen, tiger 10.4.11, CPU dual core 2.16ghz, 2 gig ram, UB. PT 7.3.6. M Box2 |
the first thing i do on an ad is wack in a marker and 12 frms after the in and before out point....
It will be interesting to see if they reject all the foreign made TVCs that start audio on first frame.
DW |
Personally i think it is pretty silly one station in canberra are trying to enforce this obsolete rule, when no one else does. i think i have ever seen one spot rejected after a freelancer had audio coming in at 2 frames. it was adjusted to 6 and life was peachy.
it will be interesting to see what happens as well if this guy tries to reject a BIG BIG advertisers spot (such as sony, coca cola etc)...
Rather stupid specs, considering we've moved on to the digital world - but good to know, if you're creating and mixing a spot, that will also air in Australia and UK. Timothy |
AUSTRALIAN POST ENGINEERS - OP 59 new standards for broadcast | davedotpez | Post - Surround - Video | 21 | 06-06-2013 07:33 PM |
Digi 003 from US - ok for Australian power specs? | tj7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-05-2011 08:47 PM |
What is TV broadcast specs for the UK? | citysoundman | Post - Surround - Video | 15 | 12-02-2009 06:09 AM |
Questions on Broadcast Specs | sundontlie | Post - Surround - Video | 8 | 01-07-2008 12:48 PM |
Broadcast Specs | Pirate Post | Post - Surround - Video | 3 | 09-21-2003 10:28 PM |
