Old 12-11-2007, 01:13 PM
nean nean is offline
Default AU Plugins also run as RTAS!?
hi all,
today i had a strange experience.
on a support session i found out that there must be some AU plugins/instruments out there which are being used as RTAS Plugin.
In such case the AU.component File is the same as the RTAS.dpm File, there is just a UNIX symbolic link!
In the Finder it looks like a standard dpm File.
That means that it could be possible to copy the AU.component in the PT Plugin Folder and rename it to RTAS.dpm
My question is, which AU plugins you can use as RTAS Plugins???
If your RTAS Plugin size is just like 4K, you should take a closer look with the Terminal!
how i found out:
there was a problem with the install routine of an RTAS instrument, after an install the Plugin was missing.
so, i analyzed the install Package .pkg with pacifist if there is a dpm file in it, or any file which should be installed in the PT plugin Folder -> none
i found a UNIX post-install script in the Installation Package and the bug in it,.... and whats really going on there,...
i wrote a patch-shellscript without spelling mistake which soved the problem!
example from the post-process script:
<font class="small">Code:<hr /><pre>
#!/bin/bash
export AUPATH="/Library/Audio/Plug-Ins/Components"
export DPMPATH="/Library/Application Support/Digidesign/Plug-ins"
export VSTPATH="/Library/Audio/Plug-Ins/VST"
function linkPlugin
chflags -R nouchg "$2"
chmod -R a+rwx "$2"
rm -rf "$2"
mkdir "$2"
chmod -R ug+rwx "$2"
chown -R root:admin "$2"
ln -s "$1/Contents" "$2/Contents"
if [ -d "$DPMPATH" ]; then
chmod ug+rwx "$DPMPATH"
linkPlugin "$AUPATH/PLUGIN.component" "$DPMPATH/PLUGIN.dpm"
fi
exit 0;
</pre><hr />
Old 12-11-2007, 06:20 PM
Phil Jeffers Phil Jeffers is offline
Default Re: AU Plugins also run as RTAS!?
Hi, Pro Tools LE only supports RTAS and AudioSuite plug-ins. If you get any other plug-in types working I'd say it's merely an anomaly and probably would not be worth exploring. VST plug-ins can be converted to RTAS via a wrapper. AU, MAS, etc are not compatible with PT's.
RAM for RTAS plugins Majorek Virtual Instruments 8 01-19-2010 07:05 AM
tdm vs. rtas plugins univox1 Tips & Tricks 20 03-17-2007 06:16 AM
PT Can't see my RTAS plugins? AudioArtCafe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-27-2004 10:55 AM
how many RTAS plugins can one run? outflowcrew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-18-2003 08:26 AM
What are the best RTAS plugins for LE? jazzsounds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-23-2003 02:28 PM
