Old 05-21-2007, 11:00 PM
cc1 cc1 is offline
Default what do grid lines do after beat detective bar-beat markers
are generated? theres always a grid line on the new bar-beat marker - but the other grid lines shown don't jibe with the new tempo ruler. what is actually happening....
Old 05-22-2007, 09:34 AM
Scott Church Scott Church is offline
Default Re: what do grid lines do after beat detective bar-beat markers
Hi cc1,
It really depends what you are doing with Beat Detective. For example if you choose Bar|Beat Marker Generation, then you are essentially creating a tempo map so that the grid moves, not your performance. In this case, if you have done the Beat Detection correctly, the grid lines that fall on Bars, Beats or Sub-Beats depending on which you choose will be aligned to the transients. So you won't hear any difference, but editing will be easier because now the Pro Tools grid is aligned with what is played. If you are only generating markers based on the Bars resolution, only barlines will lineup and any variance within the bar won't be affected. In this case, work at a lower resolution such as Betas or even Sub-Beats.
If you choose Region Separation followed by Region Conform, then you will actually be changing the performance to align with the Grid (or a groove), so that the grid lines don't move - the performance does.
Cheers,
Scott
Scott Church
Beat Detective best place for transient markers? Iron Shirt Pro Tools 10 0 05-09-2012 06:39 PM
Grid and Bar/Beat Markers scrambled and disabled after using Beat Detective!! Robbry Pro Tools M-Powered (Win) 0 02-24-2010 02:14 PM
Can't add or move Beat Detective Markers? Repooc Tserrof 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-12-2008 08:14 AM
Beat Detective, Beat markers to Tempo Ruler?!? phobia Tips & Tricks 3 01-01-2007 01:31 PM
cutting to the grid with beat detective MaKoRancid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-15-2006 12:24 PM
