Control 24 won\'t stay online
Hi All,
My brand spanking new Control 24 keeps getting knocked off line when I hit play or record. I'll get the -6088 error message about increasing h/w buffer size about 4 or 5 times before it goes offline. Pretty frustrating. I've changed ethernet cables. New creation station rack computer. 003 interface. Anybody have any suggestions ? Thanks Tom |
Re: Control 24 won\'t stay online
I am having the same issue with my HD and Control 24. When it was new, it would go offline occasionally, now it appears the ethernet is hosed.
Here is what I have tried so far, hopefully this works for you, and if anyone sees this thread and sees that I have missed something, PLEASE point it out, I don't want to have to lug this to a repair shop. Anyway: -Notice that it no longer says "welcome to control 24" on the display...Hmmm -Everything else seems to work -Made sure my Ethernet port on my Mac still works (these are known to blow up) it does -Switched cables -Reset the Ethernet on the Control 24, you do this by: 1. Press Utility 2. Press Test 3. Hold down Shift and Option and Press Ethernet 4. Press Reset 5. Press Okay 6. Exit out of the menu -Reset the Control 24 to factory default -Ran the Ethernet Test and it failed a lot--not sure what that means -Installed LE with a 002 on my MacBook Pro and repeated the above, still didn't work. -Think my Control 24 Ethernet is toasted. -I'm sad... |
Can't get Control 24 online, tried everything | Cordova Sound | ICON & C|24 | 5 | 11-20-2012 02:23 AM |
Control 24 & HD3_Mac_Won't come Online | rosindabow | ICON & C|24 | 2 | 12-04-2008 12:33 AM |
MIDI won't stay online | Igotsoul4u | Pro Tools TDM Systems (Mac) | 2 | 02-18-2007 09:44 AM |
stay off my mac | michael verdes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-14-2002 08:27 AM |
online digistudio is the only reason pt 5.2 exists?and no pt le on digistudio(online) | raape | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 11-11-2001 06:51 AM |
