Old 05-15-2007, 12:14 AM
scottgreiner scottgreiner is offline
Default I/O Setup question
Working at home on an HD2 with one interface, I do a lot of preproduction. Then I go to mix on a console with lots of Protools outputs, but have to painstakingly reassign all the I/O for every track, bus output, and aux return. Is there an easy way?
If I import the mix studio's I/O setup I get duplicates/conflicts. I have to go through and rectify each one separately. If I nuke MY aux's assigned to hardware outputs and re-assign them to the mix studio's, I lose the automation on those outputs.
Sorry if I'm missing something obvious here. It just seems to take up a lot of valuable $tudio time.
Old 05-15-2007, 05:15 AM
mixer mixer is offline
Default Re: I/O Setup question
you need to delete the old io setup first ..you can export and save to re-import later. use control delete. then import the io you want to use.
www.garyvandy.com
www.garyvandy.com
Old 05-15-2007, 06:23 AM
JKD99 JKD99 is offline
Exactly. At the mix studio, launch Pro Tools and delete their IO setup BEFORE you open your session, then yours will load with no conflicts.
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Puget Sound on Facebook
Old 05-16-2007, 12:49 AM
No no, thats not the problem - actually, there is no "problem" per se. I'm just curious if anyone has a faster methode of re-assigning I/O when splitting things out on a desk at another studio. I'd imagine the big guys have their assistant do it for them before they sit down to mix.
When I open my session, it opens fine. I then have to go and import the mix studio's I/O setup, then start re-assigning outputs and deleting duplicate assignments. I guess I was hoping for a "tips n' tricks" kind of thing for a tedious process.
Old 05-16-2007, 06:53 AM
many larger studios ours included post their io setup online...so you can do it before you come in to do your session..there is no easier way...g.
www.garyvandy.com
Old 05-16-2007, 01:22 PM
Craig F Craig F is offline
tricks like ?
Command+Option for sequential assigning (Trk 1 out o/p 1, Trk 2 out o/p 2)
Shift+Option for limiting the assignment to the selected tracks
Shift+Command+Option for sequential assigning limited to the selected tracks
It would be nice if there was a "Remap Session I/O to System I/O" setting in Pro Tools for thing like going tom and Edit Room to an ADR. Foley or Dub Stage
Thank you,
Craig
Old 05-16-2007, 04:55 PM
Andre Knecht Andre Knecht is offline
I can just see it…
It looks a little like the “Import Session Data” window, where facilities (physical I/O, busses, etc.) used in the saved session appear listed on the left, and to the right of each such entry we have a pop-up allowing us to re/assign it to what’s available (and/or defined) on the current rig. The pop-up also features the option to have a non-existing buss imported/created.
The whole thing can be saved and recalled as presets.
Yeah, I could use something like that every week.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 05-16-2007, 07:22 PM
I was thinking more along the lines of something like what the DSP Engine does, but I'll take both
Thank you,
Craig
Old 05-19-2007, 01:18 AM
tricks like ?
Not exactly, I got those
Yeah, something like that! Or maybe a dialog that would say, "these are the things that have changed in your I/O setup" with a list that follows, and the option to rename them or remap them. This would be a lot lot simpler than hunting through the pages of the I/O setup for bugaboos.
werd.
MIDI SETUP takes long to SETUP and doesnt SETUP DartagnanSosa87 MIDI 3 01-28-2013 12:02 PM
Setup question JNS Pro Tools TDM Systems (Mac) 3 03-02-2010 11:19 AM
Setup Question drebeatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-28-2009 09:29 AM
setup question gira29 MIDI 1 02-22-2003 05:35 PM
002 Setup Question wanderingstar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-06-2002 09:06 AM
