Old 08-04-2018, 06:04 AM
its2loud its2loud is offline
Default Re: Air Con in the studio, advice please.
Split air systems have directional louvers. Wherever you install it, have the louvers point towards the ceiling so it blowers the cold air up which will then fall down and blanket the room since cold air is heavier than hot. Depending on the size of your space, it shouldn’t take much to cool it down and maintain a comfortable temp.
Old 08-04-2018, 06:41 AM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
My control room is also a 20' x 20' room over the garage. Even though I have central cooling, the room gets about 10 degrees F warmer than the rest of upstairs due to electronic equipment, a refrigerator in the maid's kitchenette and water heater in the garage below. I bought a portable 10,000 btu A/C unit that keeps the room pretty cool. Even in the summer I can get away with not having to turn the 5 ton central air unit for all of my 2nd floor until about 1PM in the afternoon.
Here is a link to a picture of it in action: https://i.imgur.com/09XuQeT.jpg
It has 3 fan speeds and even a timer that I can use to turn it on early before I get upstairs. Timer can also be used to turn it off at night, but I just use the remote to turn it off manually.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 08-04-2018, 04:23 PM
Raoul23 Raoul23 is offline
Ok so the furthest away from the door is behind mixing console, when it arrives Monday hopefully the flare can be angled up so not blowing directly at me. The next problem I have is the battens behind the plaster board are not evenly spaced so I’m wondering if I could fix it to the plaster board with these
https://www.gripitfixings.co.uk
Or when the it blows the cold air will it vibrate to much
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 08-04-2018, 05:25 PM
BScout BScout is offline
The way to do this correctly is you put a larger piece of 3/4" thick plywood mounted to the wall first. Make sure it is large enough to reach over 2 wall studs at least and with at least 1" wider to either side and lag bolt it to the studs (through the drywall.) Put a layer of glue between that piece of wood too so it bonds extremely well to the drywall.
So now you have a large piece of plywood securely mounted to your drywall over the whole surface area (glue) and secured with lag bolts (left/right edges) to the wall studs. Then you mount your A/C unit to that piece of wood (you can go through it too.) The 3/4" thick wood piece will hold the securing bolts threading for the A/C strongly and you don't have to worry about where the studs are anymore. Also, remember to pre-drill pilot holes and use an electric screwdriver with a lot of torque because the grip and hold of putting those bolts through will be very strong.
Old 08-05-2018, 01:13 AM
Thanks BScout but then I will have an unsightly piece of wood hanging behind the air con unit that can be seen. As from memory the battens are quite far apart
Raoul Crane
Old 08-05-2018, 04:04 AM
Paint the piece of wood; make it an art project if you will. Think Jackson Pollock.
Here in the US they build standard walls with studs on 16 inch center. That's so you can have a standard 4x8 foot sheet of plywood secured to a stud towards each side edge (assuming a vertical placement of said wood). My house is a bit different as I think the builders were drunk. In the same wall studs can vary from 16" to 17" to 18" and inbetween center to center.
Old 08-05-2018, 07:57 AM
As Jack mentioned, you paint the wood before mounting the A/C — often the same colour as the drywall behind it so it disappears.
16” OC (on center) is standard spacing post WW2
18” OC was a common spacing in housing construction pre WW2 to save material cost for interior walls and is still used (and allowable by most building codes)
24” OC is getting more common for even more material cost savings though it takes planning (no load bearing walls, etc)
Old 08-06-2018, 02:44 PM
My system Arrived today and I’ve got my piece of wood to hang the internal fan to. Fingers crossed installation isn’t to hard
Raoul Crane
Old 08-07-2018, 03:40 AM
DIY system or do you have a contractor coming in to do the job?
Old 08-07-2018, 03:41 AM
DIY and a friend who has done a few before. According to the company I brought it from its “Easy Fit” if there is ever such thing lol
Raoul Crane
Studio Furniture ADVICE nehemiahmh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-06-2005 08:13 PM
Any advice for a studio about to upgrade to HD and Audiodude General Discussion 0 07-22-2004 09:37 AM
advice on my new studio configuration juanpablo Pro Tools TDM Systems (Mac) 2 01-13-2004 09:47 AM
Advice on Building a studio The_Jester 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-25-2002 02:22 PM
Need Studio Constructing Advice peneslapepe General Discussion 2 04-26-2002 07:03 PM
