Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 09-07-2020, 12:51 PM
Atkron205 Atkron205 is offline
Default Pro Tools 2020.9 with UR824 interface
I have Pro Tools 2020.9 installed with a UR824 interface. I have the interface assigned in Pro Tools and in a session can assign the inputs and outputs on the interface. The UR824 has a program called DSPMixFx that is used to change settings on the interface. This program seems to be over riding Pro Tools. For example I can connect a mic to one of the inputs and it works as far as running through the interface, I get signal from the interface to my monitors, the issue is Even though I can see the interface and all the inputs/outputs in Pro Tools I cannot get pro tools to manage the interface. I have tried uninstalling the DSP program with no results, The interface works the same way without Pro Tools open as it does with it open.
Thanks
Creation Station-i7 Quad Core
Windows 10
Steinberg UR824 with Behringer 8200 slave
Pro Tools 2020.9
32 Gigs of RAM
Old 09-07-2020, 02:16 PM
albee1952 albee1952 is online now
Default Re: Pro Tools 2020.9 with UR824 interface
Have you gone into Windows Sound Settings and made sure that Windows is using the on-board sound card(Realtek?) as the "default playback device"? When Windows is set to use the interface, it takes over the hardware so that PT can't take control.
Old 09-07-2020, 02:57 PM
Thanks for the reply, yes, I have windows set to use the onboard audio. it makes no difference. Somehow the DSP GUI is controlling the interface, not PT
Windows 10
Pro Tools 2020.9
32 Gigs of RAM
Old 09-07-2020, 03:53 PM
The Weed's Avatar
The Weed The Weed is offline
In many cases, with third party interfaces, it depends on the manufacturer's drivers as to what Pro Tools can do with the interface settings. What are you trying to control on the UR824 using Pro Tools?
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 09-07-2020, 09:57 PM
Not really trying to control anything, Just trying to get it to work on Pro Tools, I just installed Reaper and it does the same thing, it has to be caused by the 824 DSP GUI.
Windows 10
Pro Tools 2020.9
32 Gigs of RAM
Old 09-07-2020, 10:03 PM
falcowe's Avatar
falcowe falcowe is offline
Have you tried uninstalling and reinstalling the drivers for your interface? A bit extreme, but it shouldn't take too much time I imagine? Another thought, I assume the device is showing up for Windows to use/see? And does it work to route windows audio through? Just making sure the interface is functioning properly.
Did something change in the Mixer interface/settings that is locking out ProTools?
MacPro 7,1 (sigh) 16-core, 128GB ram, W5700X GPU, RME UFX+, PT 2020.5U.
Artist Mix, S1, and PT|Dock.
And too many VIs and VEPro machines.
Old 09-08-2020, 05:28 AM
JoelG's Avatar
JoelG JoelG is online now
Check the basic steps starting at pg 17: http://download.steinberg.net/downlo...4_en_gs_a0.pdf
And this is a good start for Pro Tools: https://www.sweetwater.com/sweetcare...ions-9-and-up/
Joel
Jam Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 2020 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 10 Pro
Rig:
Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM
Pro Tools 2020.5/2020.3 Compatibility with Catalina 10.15.4? derrickhou macOS 4 07-26-2020 07:46 AM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
Trouble with Steinberg UR824 and Pro Tools? Trizo Third Party Interfaces 2 01-10-2015 09:55 PM
Steinberg UR824 in use... Sardi Third Party Interfaces 2 01-08-2015 02:29 PM
