Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
Old 08-30-2020, 08:34 AM
Gamefreak Gamefreak is offline
Default Downgrading PT 2020.4 to 18.4
Hope it's the right place for this post;
In 2016 I bought PT 12.5 (Perpetual Product) with a Standard Support Plan which expired 08-11-20. Accidetally I've upgradedmy PT 12 to 2020.4, but the last version covered by my Support Plan was 18.4.
Immediately I have bought a new Annual Subscription, but it was already too late: "PT cannot be launched ("Subscription expired...") and the new subscription cannot be downloaded.
I tried to "overwrite" the PT 2020.4-version on my pc with PT 18.4 which didn't work, and neither did overwriting it with PT 12.5.
Every time the installation was interrupted with the message "Error 2753: the file "mmerefresh.exe is not marked for installation".
Do I have to completely remove PT 2020.4 from my pc and reinstall my first Version (PT 12.5) or is there any other way?
Thank you
My System: Win 8.1. Pro, Intel i7-4790, 3,6 GHz, 32 GB Ram, Samsung SSD; Steinberg UR 242
Old 08-30-2020, 08:37 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Downgrading PT 2020.4 to 18.4
Hi, welcome to the community.
Compatibility info here.
Janne
Old 08-30-2020, 08:42 AM
Okay, I've seen: wrong OS for the PT-Version...
But is there any way back to PT 12.5 or 18.4?
Old 08-30-2020, 08:43 AM
JFreak's Avatar
Just install the version you want to be using. Your license has a RELEASE LIMIT date that determines the latest version you can use. Earlier are okay. If you have problems it is very much recommended to do a clean install of OS and start over.
Janne
Old 08-30-2020, 07:27 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
To answer your question, yes, a clean install will probably be required unless you can do a system restore and or have a back up/clone of your system drive
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 32 Gig Memory:Seagate 2 TB,1TB,4TB,500gb EVO OS Windows 7 Ultimate
PT 2019.6 Native through A&H Qu-32
Old 08-31-2020, 02:50 AM
Thank you for your quick replies
Unfortunately I have no backup of my system; I would not like to change my OS because it ran stable for four years.
Now I will run the uninstaller and remove Pro Tools from my system and try a clean installation of PT 18.4 which is the last version I am allowed to load.
Old 08-31-2020, 02:54 AM
JFreak's Avatar
Clean install means starting over with OS
Janne
Old 08-31-2020, 04:16 AM
It is done!!
I've deinstalled the current PT-Version, then reinstalled PT 12.5 (didn't work...) and then upgraded to PT 18.4
...it works!
Thank you for your patience
Old 08-31-2020, 04:17 AM
JFreak's Avatar
Good to know you got it going
Janne
Pro Tools 2020.5/2020.3 Compatibility with Catalina 10.15.4? derrickhou macOS 4 07-26-2020 07:46 AM
Avid Control App Rollback (2020.5 to 2020.3) budster Avid S1, S3, Dock and Control 2 06-09-2020 11:01 AM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
