Old 11-24-2018, 08:45 AM
quangaroo quangaroo is offline
Default Trashing Prefs & Restoring Prefs - Sticky?
Is there a sticky that walks you through what you need to RESTORE or reload after trashing prefs?
Will trashing prefs get rid of my I/O settings?
I know Peter Gates has a Pref trashing app, but after you've used it, what do you need to set back up in Pro Tools?
I don't want to proceed until I've written down all the info I'll need to restart PT, but I can't find a comprehensive list.
Thanks for any pointers! :)
Mac Pro 5,1 (Mid 2012) | OS X 10.10.5 | Digi 003 | Pro Tools 12.7.0
Old 11-24-2018, 09:32 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Trashing Prefs & Restoring Prefs - Sticky?
I don't think it resets your I/O configuration, but you should probably save a copy of your I/O config anyway so you can easily restore it whenever you need to. Also, I think the Pref trashing app allows you to select exactly what you're trashing. Whenever I use it, I mainly just go into Preferences afterwards and restore my settings - not a big deal and doesn't take long. It's not something you should have to do a whole lot.
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS Catalina 10.15.7
Pro Tools HD 2020.9.1
Old 11-24-2018, 09:43 AM
Thank you for responding, Chris!
I guess my question is: which settings will need to be restored after trashing prefs?
I want to make sure I've written everything down before I jump in!
Thanks!
Old 11-24-2018, 09:48 AM
Trashing prefs will likely default IO, blank the Midi Studio settings and reset several settings(which are easy to reset if you make notes of your preferred settings). Here's how I deal with some of this stuff:
Since some things get deleted when you uninstall(like to solve a big problem, or to install a newer version), so I keep a folder that is NOT in the usual place, and save copies of IO settings and Midi studio settings, along with folders with all my session templates and track presets. As for IO, because I have 4 interface(2x HD IO and 2x 192 IO) using a mix of analog and digital, I save screen shots of all the various tabs to show how each interface needs to be set for all my stuff to work. If everything gets defaulted, I can restore hardware settings by referring to the screen shots and then in the IO setup section, I can Import Settings from my saved setup from my settings folder(which may or may not match the default settings folder).
Other stuff to reset:
Color Saturation-just double-click on the colored bit at the bottom of any track in the MIX window to bring up the color settings and click the saturation button.
Auto Save-it defaults to 10 versions and every 5 minutes(change to what you prefer; I save every minute and 12 versions)
Scrolling-this will default to none(change it in the Options menu)
Other stuff- is really a personal choice, so I would just save a text file with your preferred settings so you can just run down the list after trashing prefs.
I know this seems long winded(sorry, but there's lots to cover) but once you cover your tail with some notes, screen captures and saving copies of IO and Midi Studio stuff, it only takes a few minutes to reset everything when the need arises
Last 2 cents; if you are not saving drive images, you should(and you should do this ASAP). And while you are doing that for your system drive, you also need to be backing up every session(unless you don't care if they disappear one day.....and they WILL). If you use a separate drive for sample libraries, save images of that too. Since I make my living with this, I go the last mile by cloning my system drive to a second(identical) SSD. If I have a major meltdown, I swap out the system drive for the clone and go back to work. Total downtime? About 3 minutes
Old 11-24-2018, 10:14 AM
Thanks so much! This is exactly what I was looking for!
Now I can create a checklist & set aside the time to do it right.
As I said in my original post, this would make a great sticky post!
Thanks again!
Old 11-24-2018, 10:58 AM
tonepad tonepad is offline
Here's the sticky: http://duc.avid.com/forumdisplay.php?f=93
I usually just trash the DB and that's enough. trashing Prefs is the next level and will require resetting your personal choices. The DB just gets redone on your next PT start up. It's a good thing to do every couple of months but def if something needs burping.
My day job:
Wilson Dyer MPSE
Sound Supervisor: NCIS Los Angeles, CBS Television
Old 11-24-2018, 12:03 PM
Thanks! I will try trashing the DB first.
BTW, the link showed 3 stickys, but I couldn't determine which was the one regarding trashing prefs.
Mac Pro 5,1 (Mid 2012) | OS X High Sierra 10.13.6 | 32GB RAM // Pro Tools 2019.5.0 | Digi 003 Rack | Digi 003 Rack+
Old 11-24-2018, 09:45 PM
Just get his latest version of the app. It's a simple interface that you will understand quickly....basically just check the trash DB option for the PT version you have. From memory I believe he has a pre 12 option and then 12 option. or perhaps 10/11 is the dividing line. Sorry not at my rig. He's a great guy who will not even take donate $ for this useful tool.
My day job:
Wilson Dyer MPSE
Old 11-24-2018, 10:13 PM
LOL to confuse things here's another sticky for Pete's app:
http://duc.avid.com/showthread.php?t=340741
Welcome to confusing world of the Avid Audio Forum...there's a lot of legacy detritus but we love our community.
BTW either of these are good and developed by smart users.
My day job:
Wilson Dyer MPSE
Old 11-24-2018, 10:43 PM
Thank you for the extra info & link! It's much appreciated! :)
Trashing Prefs johnolly Pro Tools 10 6 01-13-2016 06:09 AM
Trashing Prefs & Such baaablacksheep macOS 3 04-30-2012 06:30 PM
Trashing prefs in PT 7? guy.fi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 11-02-2006 04:47 AM
Trashing Prefs kikumoto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-23-2006 05:01 AM
Trashing PT Prefs Rockman-Songwriter Pro Tools TDM Systems (Mac) 1 06-21-2003 05:26 PM
