Old 09-28-2013, 08:35 PM
BigJohnD BigJohnD is offline
Default tuning acoustic guitar with eleven rack
Can you tune an acoustic guitar with eleven rack's tuner using a microphone? The tuner works great if I use a guitar's pickup, but the tuner shows no signal when the guitar is played through a mic with the pickup cable unplugged. My eleven rack seems to record to a PT stereo track just fine. I tried the tuner in stand alone mode and through PT interface.
Using PT 10.3.6 on windows 7. 11 rack has latest firmware update (1.1.6, I think). I'm probably doing something simple wrong.
Thanks,
John
Old 09-28-2013, 08:59 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: tuning acoustic guitar with eleven rack
You can, but I'm not sure about how accurate it is when using a mic as I've never done it that way.
All you need to do is change the RIG INPUT to MIC, right now you probably have it on GUITAR.
Also 2.0.1 is the latest Firmware. 1.1.6 is the latest DRIVER version for Windows
You also mentioned you are on 10.3.6, there is an update available for Pro Tools 10.3.7
http://avid.force.com/pkb/articles/d...-3-7-Downloads (download at bottom of page)
Brian
Windows 10 Pro 64 Bit
Pro Tools 2020
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Instagram
Old 09-28-2013, 09:16 PM
Benoni,
Thanks for the reply. You are quite riight, changing the rig input to mic did the trick. By the way, the tuner seems to do a good job with an acoustic guitar this way, very stable signal.
Thanks again,
John
Old 09-29-2013, 09:58 AM
nst7 nst7 is offline
There's also a very accurate tuner plugin that comes free with Protools called "TL Intune". You might find it easier to use for your acoustic so you don't have to switch the Rig input back and forth. Just insert it on the track you're recording your acoustic to. You might even use it in your electric as well. It may be even more accurate than the 11R's built in tuner.
Old 09-29-2013, 03:55 PM
Benoni's Avatar
Originally Posted by BigJohnD View Post
Benoni,
Thanks again,
John
Cool, glad it worked for you.
The RIG INPUT setting is an important one to remember and one of the first things you should check when you are not getting the correct signal.
For example, I had a short freak out moment once when I plugged in to my 11R and no sound come out! I adjusted all the different VOL settings, made sure my IO was correct, defaulted the IO, turn the rack OFF and back ON, nothing..... Then I finally remembered I had done some re-amping All I needed to do was switch the RIG INPUT from REAMP to GUITAR - and I know this has happened to others as well.
There are so many possible internal settings in the Eleven Rack that it is really a good idea to familiarize yourself with them, when you get time, scan through the .pdf manual, you will be glad you did.
Enjoy.
Brian
Pro Tools 2020
benonistudio.com
Plugin Deals
@benonistudio
Instagram
Old 09-30-2013, 06:00 AM
Cowboy Bob's Avatar
Cowboy Bob Cowboy Bob is offline
Originally Posted by Benoni View Post
For example, I had a short freak out moment once when I plugged in to my 11R and no sound come out! I adjusted all the different VOL settings, made sure my IO was correct, defaulted the IO, turn the rack OFF and back ON, nothing..... Then I finally remembered I had done some re-amping All I needed to do was switch the RIG INPUT from REAMP to GUITAR - and I know this has happened to others as well.....Enjoy.
Yup Did this one too the first week I had my 11R, got totally PO'd until I looked at the GUi and remembered what I had done in an earlier session.
I've even done it again once or twice since, but now I immediately know where the loose connection occurs....it's between my ears.
Squaw Creek Road Studio
Bob
Pro Tools Standard (current version)| Avid Eleven Rack ERXP | Sibelius Ultimate (current version)
3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Catalina |
Focusrite Clarett 8Pre X | Lenovo i7 ThinkPad | Win 7 Professional | Avid 003 + Rack |
Old 09-30-2013, 06:15 AM
sunburst79 sunburst79 is offline
Interesting. I seen to have short there. Its not intermittent. It goes completely dead once and awhile.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 09-30-2013, 10:11 AM
Something I run into when trying to tune an acoustic through any tuner (I usually use a very expensive Peterson StroboTuner and not one of the cheaper ones) is ambient noise getting into the mic and causing the strobe to bounce all over the place. I found that a good hypercardioid mic up closer than I'd normally mic an acoustic to help. Usually one of my Neumann TLM103's or an AKG C414 with the right pattern selected.
Just be thankful you don't have to make fine adjustments for intonation on an acoustic like on an electric using a mic
Jack
QAPLA!
Old 09-30-2013, 10:46 AM
DonaldR DonaldR is offline
Originally Posted by musicman691 View Post
I usually use a very expensive Peterson StroboTuner ... one of my Neumann TLM103's or an AKG C414 ...
Wow! I think you have the most expensive tuning setup on the planet
Old 09-30-2013, 11:17 AM
Just using the stuff I have in my studio, that's all.
Jack
QAPLA!
Eleven Rack Only Recording Dry Guitar Signal no FX Imran5000 Eleven Rack 18 07-20-2017 07:50 AM
Eleven Rack not at Guitar Center? PT8716 Eleven Rack 30 04-20-2013 09:43 PM
Recording Guitar with Eleven Rack and Focusrite Liquid Sapffire 56 Citizen_M Pro Tools 10 1 03-03-2012 08:30 PM
Can I go Guitar>Pedals>DI XLR out to Eleven Rack? (using Mic input for guitar) electricfiddle Eleven Rack 5 12-12-2011 06:57 AM
