Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 06-20-2019, 12:04 PM
Ulf Ulf is offline
Default Working with System 5 and Avid MC Pro pro???
Is it possible to have a System 5 with 3 408´s, one 401 and one 402 and a SC264and then add a Avid MC Pro to work alongside and if it is possible how do i do that?
If I have both running Eucon (Avid MC Pro and System 5) one will take and block for the other! So do I have to turn off Eucon on one to get the other to work???
Best regards Ulf
Mac Pro 2x3,46 GHz 6-Core OS 10.13.6
System 5 SC264D, CM408x3, CM402, CM401
AM713, MA703, ML530, MC524, FC726
ProTools Ultimate 2019.5, Avid MTRX
Old 06-21-2019, 07:24 AM
EddieJones's Avatar
Default Re: Working with System 5 and Avid MC Pro pro???
They can run together on the same (EUCON) network but you would have to assign the Workstation to one or the other not both at the same time.
Old 06-21-2019, 12:41 PM
Ulf Ulf is offline
Is it possible to have the 408´s following when i switch from one Eucon master to the other???
Best regards Ulf
Old 06-21-2019, 12:50 PM
EddieJones's Avatar
No...completely different operating systems.
Old 06-21-2019, 03:10 PM
Ulf Ulf is offline
Sorry to sound slow, but You either use the 408´s to the System 5 Fusion or to the Avid MC Pro?
No possibility to combine between the two?
Best regards Ulf
Old 06-21-2019, 03:34 PM
EddieJones's Avatar
Correct.
Old 06-22-2019, 02:52 AM
Ulf Ulf is offline
Well Thank You for your feedback! Most appreciated, best regards Ulf
Working With Avid Mojo - Avid QT LE Codecs SPC Post - Surround - Video 7 07-22-2009 02:41 PM
How to get this system working - please :-) brianoreilly Digidesign Hardware & Software 2 04-09-2007 02:45 AM
My new system isn't working with my 001 punkd4life 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 11-30-2006 08:21 PM
Mix system not working in OSX storymaster2k Pro Tools TDM Systems (Mac) 1 05-23-2005 08:18 PM
ptf not working on my system jaylen Digidesign Hardware & Software 3 09-12-2003 06:09 AM
