#21
Re: Fine Adjustment 12.6 = Showstopper
+1
#22
Short cut changes - how to clear a volume node PT 12.6
Hi there. I was used to using command/option to remove volume nodes while mixing on the edit window - did it all the time. That option appears to have gone away with PT12.6. Anyone know how to do this with the new version?
Thx, David |
#23
Please, put it back the way it was. While Shift is directly above Ctrl, so it would seem not to be that big of an issue as you can cover both keys with one finger, you have to remember to hold down Shift BEFORE you hold down Ctrl or you get snap to grid happening.
Whose brilliant idea was this? I thought Avid was starting to "listen to their customers"? Who did they listen to on this? Not anyone who actually uses Pro Tools apparently. Maybe if we all start support cases about this "feature" they'll get tired of us and revert it back - or at least give us an option in Preferences to have the old behavior rather than the new. I can dream can't I?
#24
Major, Unwanted Change In PT 12.6...
Be aware of this. If you use Clip Gain or do MIDI editing, this, supposed, improvement in Pro Tools workflow in 12.6 is going to really, significantly affect you.
I can't think of one person who would have asked for this. Can we please have an option in Preferences to turn this "feature" off so we can have the old, normal, fine tuning behavior?
#25
Re: Short cut changes - how to clear a volume node PT 12.6
Have a look at this thread. It may explain what's happening.
#26
Thx - and just figured it out - it's now FN/Option click to remove a node - what a pain... been using that shortcut since '00 for post audio and music - ah well - I'll adjust... seems a few other things have changed slightly too... not sure why...
#27
#28
Here's a kluge:
Set the Grid to 1 sample. Now the node will only move 1 sample when you just use CTRL. The only problem is, to get the .1 db fine tuning, you still have to use Shift as well as Ctrl. At least with this kluge, you don't have to remember to hold down Shift before you hold down Ctrl. Not ideal, but an easy work around until - yeah right - Avid come to their senses and, since I'm sure they won't be changing it back, at least give us an option to revert to the old behavior in Preferences. <sigh>
#29
Re: Major, Unwanted Change In PT 12.6...
Here's a kluge:
#30
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Fine Fader Adjustment On iPad? | producedbyriot | Avid S1, S3, Dock and Control App | 4 | 09-10-2016 01:00 PM |
Fine Adjustment on AAX seems to be Broken? | Neil Pickles | AAX Plug-ins | 4 | 06-07-2013 01:39 PM |
fine adjustment of breakpoints not working | levelaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-03-2010 06:42 AM |
Fine volume adjustment | gbours | Pro Tools TDM Systems (Mac) | 3 | 05-02-2006 07:23 PM |
Strip Silence and Fine Adjustment... Still a bug? | SimpleNatureSpirit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-21-2004 11:22 PM |
