Old 07-13-2013, 07:44 PM
adamfrey adamfrey is offline
Default "Playback engine does not support 44.1 PROBLEM
So got the new 11. When I try to open a 96k session and have the Firewire solo set to 96k, it says "Playback engine does not support 44.1...." But the session is in 96k. When I change the Solo to 44.1 and try to open the file again, it says "Playback engine does not support 96k..."
Any advice please....
Adam
Old 07-13-2013, 07:56 PM
justus1900 justus1900 is offline
Default Re: "Playback engine does not support 44.1 PROBLEM
Go into the Firewire solo settings and change them to 96K then restart the computer and open PT first. If that doesn't work you need to Post if you are on a PC or MAC.
Producer/Engineer/Musician
RIAA Platinum Sales Award: Lisa Stansfield "Affection"
Main:
Model: Dell Precision T1500 Minitower
OS: Windows 10 Pro 64 Bit SP1
CPU: Intel® Core™ i7-860 (2.8GHz,8MB)
Memory: 32GB (4 X 8GB)
SanDisk 480GB SSD
AVID: Digidesign Digi 003 Console
Pro Tools 2018.10
Portable:
Model: Acer Aspire E5-575
OS: Windows 10 Home 64 Bit SP1
CPU: Intel® Core™ i5-6200U
Memory: 12GB
SanDisk 256GB SSD
AVID: Fast Track C400
Pro Tools 12.5.0
Old 07-14-2013, 07:00 AM
I'm on a PC. thanks. PT 8 worked fine.
Old 07-14-2013, 07:33 AM
Start>Control Panel>Sound> (right click on FireWire Solo) in Playback and Record. Select Properties> Advanced Tab> Uncheck (Give exclusive Control...) Apply for both Playback and Record.
Main:
SanDisk 480GB SSD
Pro Tools 2018.10
Portable:
Memory: 12GB
SanDisk 256GB SSD
Pro Tools 12.5.0
Old 07-24-2013, 04:25 PM
That still not seem to fix it. Any other ideas? Thank you for the help.
Old 08-27-2013, 12:34 AM
ziphler ziphler is offline
This problem has come up over and over over the years and different versions. It has to do with interference from the computer's sound card. I have a 003 firewire and PT10.3.6 and I found a simple solution.
Click Cntrl-Alt-Delete then select task manager. Click the services tab and scroll down until you find "Windows audio service" and "Windows Audio Endpoint Builder". Right click each and select stop service. You have to stop Endpoint Builder or it wont let you stop Windows Audio. Now go back to protools and try again.
Old 08-28-2013, 02:10 AM
guatamas guatamas is offline
Or disable your interface in the control panel/sound
This works for me, although the only downside is if you want to use iTunes you have to re-enable the soundcard
Old 08-28-2013, 12:36 PM
lowlights lowlights is offline
I get this same error with an MBox Pro (3rd Gen); when opening PT 11 sessions ... sometimes. Kinda random. I have tried using my mBox Control Panel, but even that is iffy.
I'll try some of these fixes. I'm also on a PC (Win 7, 64-bit Home Edition)
Old 09-14-2013, 04:24 PM
Disabling the Windows Audio Service and Windows Audio Endpoint Builder using the Task Manager cured my ills.
[Must restart these processes to hear YouTube/WMP type audio again, but ... so?]
Old 10-10-2013, 03:44 PM
Pinball Wizard Pinball Wizard is offline
Thank you!
I had exactly the same problem with Win 7 professional 64 bit. Files opened properly with PT10 but not PT11. Your suggestion completely fixed the issue for me.
Main Workstation: Pro Tools 2018, Windows 10, HP Z440 Xeon 6 core Broadwell 3.6GHz, 32 GB DDR4, Omni, Sync HD, UAD 2 PCIe card
Edit Room: Pro Tools 8LE 8.0.5, Windows 10, HP Z400 Xeon 6 core 12 GB DDR3, Eleven R, UAD 2 PCIe card
Both systems old & previously Avid qualified
"The current playback engine does not support a sample rate of 48 KHz" error when tr eyeshow Pro Tools M-Powered (Win) 19 09-09-2015 10:10 AM
Playback engine support problem... jjtarnow macOS 3 10-19-2014 03:22 PM
"The current playback engine does not support a sample rate of 48 KHz" E-Lister Windows 3 02-25-2012 11:54 AM
"The current playback engine does not support a bit rate of 48kHZ" M-powered 8 beasleymusic Pro Tools M-Powered (Win) 1 04-02-2011 03:17 PM
Playback engine support problem... jjtarnow Pro Tools M-Powered (Mac) 0 01-09-2011 11:18 AM
